Fridge design on 12v battery?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusKyle, Feb 15, 2023.
  1. PriusKyle
    PriusKyle Junior Member
    62
    Virginia
    Hey all,
    Thinking about getting a real car fridge (60w) for my Prius and it comes with a cigarette adapter. When the car gets shutoff, will the fridge drain my 12v and make the car temporarily inoperable?
    Thx in advance.
  2. Leadfoot J. McCoalroller
    7,152
    6,703
    Pennsylvania
    2018 Prius c
    If you use that included cigarette adapter in an unmodified Prius dash socket, the power will be cut whenever you shut down. Your battery will be fine.
    We have a small fridge for the cars and it comes with a secondary defense system to keep the battery charged: if it detects the voltage is getting kind of low, it turns itself off in the hopes that it saves enough power in the battery for another startup. We don't have to worry about that in our Prius, but in our other car the cig socket is not switched- hot to the battery at all times.
  3. PriusKyle
    62
    Virginia
    Thx!
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    IF the power is connected to a socket that stays powered when the vehicle is OFF.......then yes, in just an hour or two most likely.
  5. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    StarCaller likes this.
  6. ChapmanF
    15,531
    If this is the kind of fridge that uses 60 watts more or less constantly, then knowing your Prius comes with a 540 watt-hour aux battery, you can do the math and see how long a fully-charged, new-condition aux battery would hold up that fridge (if there were no other loads, and you didn't mind it being fully discharged at the end).
    Then take that and cut it in half or smaller, to account for (a) probably not having a brand-new aux battery, (b) the aux battery in a Prius usually not being fully charged to start with, (c) a few other loads that stay active when the Prius is off, and (d) not wanting it to fully discharge.
    Of the different kinds of fridge you can get, usually the thermoelectric kind are less money, but those are the ones that typically will draw 60 watts or so more or less the whole time you're using them.
    The kind based on compressing refrigerant are more money, but use a lot less juice, so the battery can hold them up longer. (They'll draw more than 60 watts when cycled on, but they're cycled off a lot of the time.)
  7. Doug McC
    Doug McC Senior Member
    1,000
    376
    Midwest
    2022 Prius
    540 watt-hour?? Do they really have that much capacity?
  8. Leadfoot J. McCoalroller
    7,152
    6,703
    Pennsylvania
    2018 Prius c
    You might be confusing a watt-hour with a cold cranking ampere.
  9. Doug McC
    1,000
    376
    Midwest
    2022 Prius
    I’m not. Off the top of my head (it’s too blanking cold to step in to the garage to check it) but I think my battery’s CCA is around 295 and the other rating is 45 (amp hours or is it reserve capacity?). Neither one of these converters to that watt-hour capacity do they?
  10. fuzzy1
    10,167
    45 amp-hours X 12 volts = 540 watt-hours.
  11. Doug McC
    1,000
    376
    Midwest
    2022 Prius
    Thanks! (Sure beat getting cold to find out) :)
  12. Leadfoot J. McCoalroller
    7,152
    6,703
    Pennsylvania
    2018 Prius c
    Amp hours x 12(volts) gives Watt hours. 45 x 12 = 540
    Doug McC likes this.
  13. Doug McC
    1,000
    376
    Midwest
    2022 Prius
    And thanks to you also (saved me the pain of the cold) :)
