Friend's Prius problem
Discussion in 'Newbie Forum' started by Pormoonman, Feb 6, 2011.
  1. Pormoonman
    Pormoonman New Member
    Winston Salem, NC
    2001 Prius
    I'm brand new to this chat site and I'm trying to help a friend with his 2001 Prius. He had the battery replaced by an independent shop. Inadvertently the key was left on for an extended length of time and the old battery was run down at this shop. They replaced the battery and charged the owner even though it was their mistake. Now, the car will run about 40 miles and then all the gages go hay-wire and the car stops. It will crank after an extended time has passed. The garage is telling him it need a new
    "main" cpu and the cost for it is $800 because it is only available from the dealer. Is he being given the correct information or is this garage trying to fleece him?
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Might be fleecing him, but it doesn't matter. If a garage makes a mistake and gets the customer to pay for it they and everybody else should go somewhere else.
  3. Patrick Wong
    18,200
    6,479
    We need more info regarding "gages go hay-wire". Please be specific about which warning lights appear on the instrument panel and the multi-function display?
    Also, what DTC (diagnostic trouble codes) are logged by the car?
    If the car will run for a 40 mile distance, then I would question the need to replace any ECUs. More likely the car has an overheating problem, perhaps the inverter coolant pump has failed.
  4. Pormoonman
    Winston Salem, NC
    2001 Prius
    There hasn't been any over temp warnings. Would the inverter coolant pump failure show up as a coolant over temp warning?
  5. Patrick Wong
    18,200
    6,479
    It may not.
    What warning lights do appear?
  6. Pormoonman
    Winston Salem, NC
    2001 Prius
    It's random lights flashing and then the engine goes dead.
  7. bisco
    49,534
  8. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I have a light titled random on my Prius. It's right next to my BS detector.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Picture, video or it did not happen. ;)
  10. Bob64
    1,540
    92
    Virginia
    perhaps they zapped the 12v inverter somehow? Battery runs down, and then causes funky stuff with lights. That or the replacement battery is bad.
  11. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Hmmm..."CPU and crank" sounds very trollish. And which battery, the 12V? Prius don't crank in the traditional ignitionn sense and what's with the CPU terminology?
    Oh, boy...here we go...
  12. Guy in WNY
    Guy in WNY Junior Member
    83
    17
    Western New York
    2018 Prius Prime
    Pretty fishy alright. Prius does not "crank" when you "put the key in" (Does 2001 have a key FOB? What about keyless?) in the dash slot every time, it depends on a number of factors.
    So, you're telling us somebody put the key fob in the dash slot and pressed the "Start" button and went away? Is that it?
  13. Patrick Wong
    18,200
    6,479
    If the problem is indeed the random appearance of warning lights, then I cannot offer you any suggestions other than to have a local Toyota dealer confirm the problem and provide a diagnosis. If you can identify specific warning lights being on, then perhaps we can comment.
    Classic Prius has a traditional key and ignition key slot. You twist the key to unlock the steering column and move through the various operating states: IG-OFF, ACC-ON, IG-ON, and READY. The key has an RFID head that communicates with the immobilizer ECU. There is no fob.
    I think that some of our members have their troll sensitivity set to a very high level. It is not reasonable to expect that a new poster will use the very specific terminology that regulars are familiar with.
