Front and Rear Brake Pads OEM?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ednorton, Nov 22, 2021.
  1. ednorton
    ednorton Junior Member
    49
    delaware
    How important is it to get Genuine Toyota Parts for Brake Pads? I know that Bosh pads get really good ratings, but they are only about 15-20 dollars cheaper? Just stick with toyota? Also is it necessary to change anti-squeal and shim kit? I have a 2012 with 120000. Thanks for any input!
    wheelz1980 likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    As long as you get ceramic most brands will do and for shims, most are glued on
  3. ednorton
    49
    delaware
    So in terms of the the shims and anti squeal detectors, they usually need replacement, or they usually can be reused, thx
  4. ednorton
    49
    delaware
    I understand about the fact that the shims are usually glued on. What I am puzzled about is, why does Toyota a offer a shim kit for purchase if the shims would already be glued on to the new pads? Thx
  5. Mendel Leisk
    41,876
    Cus the shims aren't glued on.
    Something you replace every 10 years or so, why scrimp?
    ednorton and ASRDogman like this.
  6. Mendel Leisk
    41,876
    I’ve reused shims (on past vehicles), but they do rust. With the Prius pad longevity, I’d replace them; they’re $10~20 for front or back set.
    ednorton likes this.
