FRONT Blue Emblem replaced
Discussion in 'Gen 3 Prius Accessories and Modifications' started by DeanFL, Jul 20, 2009.
  1. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    What a simple job!
    1. Three push clips to remove to get the top black plastic shroud panel off as shown in pictures. Only need a very small flat screwdriver to twist and pull up the small center portion which will release the pressure on the lower clip area - and simply pull off. Completely reusable.
    2. Unless you have monster hands, simply reach through the open hood latch area and push in at least two of the plastic latches holding the chrome emblem into its three mounting holes. It will easily pull right off, once you manage to find the latches (tight space).
    3. The blue/black plastic pulls right off the emblem. Clean the front and apply the film (aprox 4" X 7" - ANY color & pattern YOU want!). Trim with Exacto knife. Snap back into the emblem and clean.
    4. Insert the three mounting posts into the socket and push in - click-click-click. It's in.
    5. Place shroud panel into position and reinsert the three clips.
    Done - it took me 25 minutes. Now, both front and back have the new carbon fiber emblems. I'm no longer blue - which clashed terribly with the red.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Cool. Will this mod affect those with the AT package (as the radar is part of the emblem)?
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Excellent DIY instructions once again! Thanks.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Is the front emblem metal or plastic?
    Is it in fact flatter than the back emblem? (meaning using the normal front emblem from the sigma set won't work)
    Any ideas how to gold chrome it? Is painting it the obvious solution?
    Thanks....
  5. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Do they have this carbon fiber film in black (to provide more contrast between chrome and the backing)?
  6. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    Dean, that looks FANTASTIC! I have a customer who would love this mod. I'm going to point him to this thread.
  7. DeanFL
    1,015
    355
    1. Thanks Jeff. Very pleased with the look. Your service dept / body shop should offer the emblem replacement as a service (commission on $$$ profit...)
    2. Available film style/colors:
    Metro Decals
    I went with them after a google and saw styles I liked. Price was certainly right and I had it in 4 days.
    3. Emblem is plastic. Front larger than the rear but otherwise same. If you're set on gold for your Sandy Beach - it would be a simple job to spray paint it any shade, ie gold. Then a clearcoat. Should hold up very well to the elements I'd suspect.
    4. The AT package - I did see on other threads indicating interference may be expected. My V is not AT so can't confirm.
    Really - anyone that's slightly handy would be able to customize the emblems - the front one is so simple. The rear more involved as the inner hatch panel must be removed to access bolts for outer panel as noted in the other post.
  8. greylar
    greylar New Member
    283
    38
    Montana
    Wow Dean, Fantastic. Yet another awesome mod. Thanks to you I got the courage to pull the panels off the back hatch and re-route my aftermarket backup camera. Everything went smooth.
    Thanks for being out in front on these mods.
    G
  9. zippo
    zippo Junior Member
    28
    Campbell, CA
    I was talking with a guy about tinting windows and other of these cosmetic modifications on Saturday. I mentioned changing the hardware emblems to change the chrome color to gold tones. He mentioned that it would be trivial for them to take the old emblems off, plate them with the gold tone and put them back on. So, you might check out a detail shop. I do not have any good measure on the reliability of this guy's information at this time. I was just asking a lot of questions to get information and this bit seemed . . . interesting.
  10. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Yeah, I wondered if a body shop might not be able to do this cheaper than the $400 kit from sigmaautomotive. Sigma told me by e-mail the front emblem for the AT package is considered part of the $900 radar part, so it's not clear whether it's nearly so easy to take in and out as on the non-AT cars. I guess I'll have to break down and open up my hood! :D
  11. santaclaraguy
    santaclaraguy New Member
    Oregon
    nice job!
    SCG
  12. drspielman
    drspielman Grand Master Chief
    112
    Dean,
    Very cool job. I want both of these on my car (coming this Saturday!!). It would match so well. Do you have the template to use? I think it would look great with my winter gray color... Awesome job.
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Caswell Inc. - Plug N' Plate® Brush Plating Systems, scroll down Gold Kit = $60
  14. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Awesome mod!!! Great PICS/DIY!!! Thanks for sharing!!!:rockon:
  15. DeanFL
    1,015
    355
    Man, it's been so long ago, I almost forgot I did that. The blue clashed so badly with my red.
    For you folks that would like to replace the front emblem backing at least - this mod is SO SIMPLE. Really. So don't let concern about ability etc to limit you. And only a very small screwdriver (to get the clasps up for the black shroud) is needed.
    Now the rear emblem is another story....
  16. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I'm still waiting to see some brave soul attack the front emblem on their AT radar equipped car. I know I don't want to be the first! :D
  17. DavidA
    2,325
    1,811
    Chicago western burbs
    <------------------ My current avatar hasn't forgotten. It is still shaking with fear.
  18. royrose
    royrose Senior Member
    1,389
    948
    Foot of Pikes Peak
    Dean,
    I did the mod and it was even easier than you said. I didn't remove the black shroud. There is a cutout area in the shroud just to the right of center. It is visible in one of your pictures. I was able to slip my hand through there and pop the badge right out.
    Thanks for sending me the film. It looks great. I'd post a pic but it looks exactly like yours!
  19. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Looks great! With a red car the mod is almost a must. I do think the blue logo looks good on some other colors though.
  20. bluemonday
    bluemonday New Member
    151
    26
    St. Louis
    How reversible is this? I assume the film adheres to the badge? I wonder if something that didn't adhere could be used and held on by the top part of the logo/badge, and be durable, but also more easily reversible.
