Front Brake pad replacement
Discussion in 'Gen 3 Prius Main Forum' started by donzoh1, Sep 3, 2025 at 8:43 AM.
  1. donzoh1
    donzoh1 Active Member
    447
    153
    Lenexa, KS
    On my 2013, I am doing front pads and rotors. I disconnected the 12v before starting. Now, I'm ready to compress the caliber pistons but wondering about what to do next. If I just compress the pistons. I will force dirty fluid back through the system which I've heard can mess up the actuator. If I open the bleed screw, air might get in and then require system bleeding, including Techstream which I dont currently have. Any suggestions are appreciated.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,781
    6,031
    Texas Hill Country
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    666
    264
    Dodge Co. Wisconsin
    2017 Prius v wagon
    3rd post with the same title
  4. ChapmanF
    17,644
    Indeed, yuck.
    I start by attaching some clear tubing to the bleed screw, looped upward (over a spring coil or something nearby) and then down. I start with some brake fluid in the clear tubing, so if anything flows inward when I crack the screw open, it will be brake fluid and not air.
    Generally, there isn't much inward flow. The piston is just sitting there, then you crack the bleeder open and start pushing the piston, which makes outward flow. Then close the bleeder again before removing the compression tool.
    donzoh1 likes this.
  5. donzoh1
    447
    153
    Lenexa, KS
    I would assume that if possible, it is best to have some pressure on the caliper as the bleed screw is cracked open. I like the idea of clear tubing with an upward loop.
