Front brake pads
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by james909, Dec 12, 2019.
  1. james909
    james909 Junior Member
    43
    Leeds, U.K
    For my annual inspection I got a warning that my front pads are wearing thin. What do you think?
  2. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    Can't really see them from the picture. What do they measure? I believe 2mm is the replacement thickness.
    SFO likes this.
  3. Mendel Leisk
    38,726
    Yeah, well focused picture, of the brake rotor top edge. It is tough to get a decent pic.
    That said, I can discern the brake pads in the distance, looks like 4~5 mm? One millimeter is minimum thickness, but if they were 2 or even 3 mm, I'd be getting antsy.
  4. james909
    43
    Leeds, U.K
    Thank you. I thought the same 4-5 mm. I have a focused picture of the other side. 20191212_113919.jpg
  5. Mendel Leisk
    38,726
    Seems like excessively wide rust zone on the rotor face?? First pic seemed like that too.
  6. james909
    43
    Leeds, U.K
    True but it's outside of the brake pad contact area. It's because of the salt on the roads in winter.
  7. Mendel Leisk
    38,726
    Ok. Yeah hard to judge the scale. If pad's not running on that zone, n'mind.
  8. ChapmanF
    15,614
    Those rust bands at the inner and outer rotor edges just keep growing, and carving away the pads like so:
    It never stops being technically true that it's "outside the brake pad contact area", but only because the brake pad contact area keeps getting smaller as the top and bottom edges are carved away. :)
    It's not so easy to see how far along it really is, without taking the pads out for a look-see.
    #8 ChapmanF, Dec 12, 2019
    dig4dirt and Mendel Leisk like this.
  9. james909
    43
    Leeds, U.K
    The rust band isn't as wide as it looks in the pictures. I think the angle has distorted it. Front on it doesn't look so bad but I get what you are saying. If I change the rotors it will start rusting again. I occasionally do a high speed friction brake in neutral to clean them.
    dig4dirt likes this.
  10. oldtechaa
    336
    222
    NZ
    2013 Prius Alpha
    Your pads look fine. I'm at about 2 mm myself, and I'll probably change next inspection in 5k, maybe 10.
  11. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    I would say spring time if not sooner, def think about changing everything out. pads and rotors
    Those rust zone probably keep traveling into the pad and soon wont be enough for a hard emergency stop, possibly
    The neutral braking is helping, but they may be too far gone to have complete surface contact
    and pads may even start chipping/chunking off if not already
  12. George W
    George W Senior Member
    911
    511
    San Antonio
    In the mid 80's, German's were using dried pig piss to melt ice because they were concerned about salt corrosion. I thought it might be adopted in the States.
  13. ChapmanF
    15,614
    Isn't it a shame how much thickness is left on the pads in #8, everything fine except for the carving?
  14. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    OP got a warning?
    Verbal (or written) warning from an inspection station employee or dash board warning
    If employee, take "with a grain of salt" as I would disagree.
    If dashboard I would pay attention and agree.
    To my eyes, from the picture; pads look okay.
    Note the center wear grove in post 8 photo as a positive replacement point of wear guideance.
    I am unsure if 1 mm or 2 mm is the recommended remaining pad thickness, before replacement.
    Calipers et al sure could use a cleaning and probably the pins re-greased.
    Again from photo, pads "have some meat" left and appear okay.
