2013 Toyota Prius with 70K miles
Discussion in 'Gen 3 Prius Main Forum' started by jacques001, Dec 21, 2016.
  1. jacques001
    jacques001 New Member
    Vermont
    2014 Prius c
    I have been driving the 2014 Prius C One for almost two years. I leased it, and have to make a decision soon whether I lease another car or buy one.
    I found a used 2013 Toyota Prius that has about 70,000 miles on it. The asking price is just under $10,000.
    I test drove it today for about 15 minutes (not on the highway). I noticed that the breaks made some noise, perhaps caused by rust. The driver's steering wheel also seemed to favor one side--I'm not sure if that's just a minor issue or my imagination. I am getting the vehicle inspected at a Toyota dealership very soon.
    Does this seem like a good deal? Anything I should be worried about?
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Having good maintenance records is a big +. A comprehensive check up at an authorize dealer will also give you piece of mind. Good luck.
    P.S. Sounds like a heck of a deal.
    49,821
    if it checks out clean, and you're comfortable with the brakes and steering wheel, then yes, a very good deal.
  4. Mendel Leisk
    38,990
    That could be just be the tires. There's a term: conicity, referring to the tire profile getting kind of "peaked". Often swapping the front wheels left/right will dispel the pull, and prove that's what's happening.
  5. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    Assuming this is a lv 1 or 2, that seems like a good deal considering you might need tires and or a 60k service. Brake noise is likely just rust from sitting
  6. mrbigh
    3,686
    699
    Long Island, NY
    Also may be a tire inflation issue by a single psi
