Front caliper bleeding
Discussion in 'Gen 2 Prius Main Forum' started by GhostmanOn3rd, Apr 3, 2023.
  1. GhostmanOn3rd
    GhostmanOn3rd Junior Member
    Middle Tennessee
    I know my front right caliper is sticking on my gen2. Can I get away with swapping out the caliper and doing a regular bleed on the single caliper if I only swap one caliper? If so, I’ll likely go ahead and swap the left. Thanks for any insight.
  2. ChapmanF
    18,865
    What kind of bleeding you might "get away with" may depend on how carefully and effectively you can prevent fluid running out of the disconnected brake line and air proceeding up toward the actuator. Things are simpler if the air is only down at the caliper.
    Have you looked over this thread to learn about tools that will let you use the actual bleed procedure? :
    Gen2 OBD2 app review | PriusChat
  3. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    the front brakes doesn't need a scan tool (or techstream) for bleeding, it can be done using the conventional method. You only need the scan tool for bleeding the rear brakes since it's electronically controlled (ABS pump) No need to bleed both if you're only working one 1 side, unless you lose a lot of brake fluid and introduced air in the master cylinder.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
  5. ChapmanF
    18,865
    Yes, sometimes you can get away with bleeding a front caliper that way, if you were careful enough and effectively prevented fluid running out of the disconnected brake line and air proceeding up toward the actuator.
