Front Door Panel Clips
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Metrolens, Apr 2, 2018.
  1. Metrolens
    Metrolens Member
    190
    35
    Hi all, I want to remove the front drivers side door panel, to be able to swap out a blown JBL speaker with a new speaker. I have a 2005 Gen 2.
    I've seen a panel removal done on YouTube, but want to have the correct DOOR CLIPS on hand in case I break one. Can anyone advise on which clips I need, and where to get them?
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    3 choices:
    1] open your wallet wide and visit your local Toyota dealer. I'm sure someone will have the p/n; I'm too lazy. I tried this once and 5 clips set me back 8 bucks. No thanks.
    2] Search Amazon or eBay for Toyota clips. Folks in both venues sell kits full of clips, so you always have the right one.
    3] Visit your local DIY junkyard. Toyotas have used the same door panel clips since Jesus was in grade school - you want the white ones. You'll find that half the door panels have already been removed so they're easy to get at. Some junkyards will give them to you, and some will charge a quarter or so. Frankly, I just put them in my pocket and smile as I leave. The ethics of that are up to you.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Part number for clip is 90467-10161. If you remove the panel carefully you probably won’t break any.
    Metrolens and egg_salad like this.
  4. Metrolens
    Metrolens Member
    190
    35
    Valde3, I bought these before you posted - will they work? Amazon says they fit my vehicle. They look right. And I believe reviewers said they worked for a Gen 2...
    #4 Metrolens, Apr 3, 2018
  5. valde3
    2,002
    745
    Finland
    If others say they fit then they probably fit. Only way to be sure is to test. Part number that I posted is just a part number for OEM clips.
    Metrolens likes this.
