Front door panel removal
Discussion in 'Gen 4 Prius Main Forum' started by randomwalk101, Mar 16, 2017.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    270
    texas
    anyone has any idea how to remove the front door panel? Is there any hidden screws/nuts somewhere that need to be removed?
    I need to open it up as something inside is rattling and is driving me nuts.
    Thanks
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    It should be posted here somewhere. Two screws, one in the handle and one in the armrest tray need to be removed. Door then can be pried off from the bottom putting your fingers in the space provided. Pry upwards. Then you will see the connectors you need to disconnect. Its pretty easy. Hopefully this helps. Someone here has posted pics of doing this.
    RCO likes this.
  3. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    This should help you out
    randomwalk101, alanclarkeau and RCO like this.
  4. randomwalk101
    532
    270
    texas
    Thanks guy. That's exactly what I want to see. Hidden screws.
    RCO and Harters like this.
  5. tucatz
    tucatz Active Member
    501
    416
    Manzanita, Oregon
    Four Touring
    Randomwalk101 - please let us know if you find the source and how you fixed it. My door panel is buzzing too. It sounds like it's coming from the window.
  6. randomwalk101
    532
    270
    texas
    Actually I haven't started. I just banged on the door panel a few times and so far no more noise. Urghh I'm sure it's temporary but if it comes back I'll open it ip
    RCO likes this.
  7. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    As every engineer knows, when any item sounds unusual, kick it and see if it stops!
    Sooner Al likes this.
