Front driver side vibrates
Discussion in 'Gen 3 Prius Technical Discussion' started by Ozmit88, Nov 20, 2021.
  1. Ozmit88
    Ozmit88 Junior Member
    24
    Toronto
    Hi guys,
    My 2015 prius vibrates from front driver side when it runs on fuel but when it's on EV it's fine.
    Any idea why does it happens ?
    Thanks
  2. ChapmanF
    18,890
    Move about half these posts over to the front passenger side so it balances better.
    Ozmit88 likes this.
  3. Ozmit88
    24
    Toronto
    I don't understand.
    If you can help that's great. If you can't than don't need to be sarcastic. I searched, but wasn't able to find anything
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    There is an engine mount in the area under the inverter, behind the radiator.
    Perhaps the engine mount has deteriorated, allowing more than normal vibration to transmit to the frame.
    Ozmit88 and zeng like this.
  6. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Engine mount related ?
    This makes lots of sense.
    Ozmit88 likes this.
  7. ChapmanF
    18,890
    Apologies. At the time I posted, you had made about six identical posts in a row of this same question. The moderator then very quickly made the duplicates go away, which kind of removed the original context.
    Ozmit88 likes this.
  8. Ozmit88
    24
    Toronto
    This is my only post.
    Why would I spam here, I am genuine prius 2025 owner with an issue
  9. ChapmanF
    18,890
    Sometimes the forum software is slow to respond and people click the Post button multiple times, or something else goes wrong. It's not necessarily that you were spamming on purpose.
    Ozmit88 likes this.
  10. xliderider
    8,140
    3,277
    Honolulu, HI
    You're apparently, also a time traveler from the future.
    Ozmit88 likes this.
  11. Ozmit88
    24
    Toronto
    Lol i meant 2015.
    It's a good strong car with 325,000km on it.
    Just the vibration at lower speed is the only problem i face.
  12. xliderider
    8,140
    3,277
    Honolulu, HI
    Over 200,000 miles, how is the engine idle? If it idles rough, the EGR valve could be stuck open slightly. That could cause rough running and create more vibration.
    Your EGR cooler, EGR pipe, and intake manifold is overdue for a cleaning as well.
    Ozmit88 likes this.
  13. Ozmit88
    24
    Toronto
    Engine is good. I hear some sound on the driver's front wheel as if something is hitting .
    But this won't happen at higher speed.
  14. privilege
    privilege Active Member
    659
    169
    Birmingham
    yes, you probably need need engine mounts
