front fender blinker lights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by smtrader, Jan 21, 2005.
  1. smtrader
    smtrader Member
    105
    Cerritos, CA
    Does anyone know why European cars (e.g. BMW, Mercedes, VW) all have front fender blinker lights..you know, those slightly behind and above the front tires?
    I saw an 04 Prius n Asia and it had those blinker lights. Super cool looking! :D Has anyone put those on their Prius in SoCal?? :roll:
  2. Speedracer
    Speedracer New Member
    378
    Nagoya, Shanghai
    It require by Law in Europe and Japan but not in U.S
  3. smtrader
    smtrader Member
    105
    Cerritos, CA
    Too bad! I like the way they look and wish I knew someone who could put them on mine here in SoCal, around Los Angeles area. Anyone??
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    I think they're a good safety feature, especially when a car is turning at an intersection or changing lanes on a highway. I've noticed most VW and Audi cars sold here retain their fender signal repeater lamp, I wish Toyota would too.
  5. KTPhil
    KTPhil Active Member
    1,379
    I'll eventually retrofit them, as soon as I figure out the wiring, and how to cut/seal the hole in the fender. I want to use OEM hardware so it can be fixed if damaged. I haven't seen a detail drawing of the part to know what gaskets and hole configuration is needed. Measure twice, cut once!
    Those lights are handy in stop-n-go traffic; cars next to you can't see your blinkers and think you are cutting them off without warning.
  6. xevious
    xevious New Member
    187
    Oregon
    Please share your technique, findings, and part numbers with us, if you will. I'm sure there are several Prius owners (including myself) who would like to add fender blinkers but aren't daring enough to be the first to drill a hole in the fender.
  7. smtrader
    smtrader Member
    105
    Cerritos, CA
    <div class='quotetop'>QUOTE(KTPhil\";p=\"68851)</div>
    Yes...please keep us informed!
  8. naterprius
    naterprius Senior Member
    1,843
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    Nate:
    Thank you! That kit looks perfect. I suppose it's a fairly easy install too??
  10. smtrader
    smtrader Member
    105
    Cerritos, CA
    Think we can get a "group buy" and even install on these mirrors????
  11. xevious
    xevious New Member
    187
    Oregon
    Nate,
    Thanks, but I'd rather have fender lights. Smtrader, please keep in touch...
  12. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    I'm in with the group buy if we can get the price down a bit.
