Front Jack Point
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen2prius, Aug 19, 2022.
  1. gen2prius
    gen2prius Member
    91
    26
    Sydney, Australia
    i-Tech
    A lot of maintenances are overdue, planning to rotate the tyres among other things. Can't see any rotation markings on the tyres, they are energy saver tyres (Michelin XM2), I think only some performance tyres are directional. So will be treating them as non-directional and following the front wheel drive pattern found on Michelin website.
    Instead of lifting the entire car, plan is to change one side at a time:
    1. RR <-> FR
    2. RL <-> FL
    3. FR <-> FL
    Step 3 requires jacking up the car at the front, using a trolley jack. Is the yellow highlight part the front jack point?
  2. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    You can safely jack it up in that spot but it's really hard to get the jack that far under the car and still be able to lever it up.
    I sometimes use that spot once the car is higher up in the air. To get things started the jack points near each wheel for flat tires are my preference because I built this jig to put on my jack. Makes everything go real quick...
    SFO likes this.
  3. gen2prius
    gen2prius Member
    91
    26
    Sydney, Australia
    i-Tech
    Thanks, that's a good idea, and reusable on many cars.
    Thinking more about it, I may use the spare tyre temporarily, so there's no need to lift the front:
    1. FR -> RR, put spare at FR
    2. FL -> RL, put freed RR to FL
    3. Replace spare with freed RL
    So I can check condition of spare and to pump it up as necessary, but still good to know where the front jack point is.
  4. 2ndgenbestgen
    2ndgenbestgen New Member
    22
    usa
    Even the lowest height floor jack gets caught on the bottom of this low clearance car. I don't know why the repair manual's recommended jack point is essentially in an unreachable position.
    You just have to use good sense and make your way there. 2nd post advice was solid
  5. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    I usually pick up one whole side of car at once . Roll tyres from front to rear on that one side . Then do other . 1 Jack etc .
  6. gen2prius
    gen2prius Member
    91
    26
    Sydney, Australia
    i-Tech
    Yeah, that's what I was thinking, position the trolley jack at left front (in between the jack markings), since the car is front heavy, the rear should lift as well. Then do the right side.
  7. Tombukt2
    12,193
    2,150
    Durham NC
    Yes I'm using a real shop type floor jack at my house it's like 4 tons of big red t o r i n manufactured thing it barely fits under the lip between it's like 8 in from the rear jack point towards the front door something like that then you jack up in the front and the rear wheel come right up off the ground it's not sloppy either you can't push on the front end and knock the front end down to the ground and vice versa I could take both tires off the car with my electric DeWalt wrench and a few seconds roll them into positions where they're going to go kneel down and be putting back on either tire front or back doesn't matter it doesn't make the car go wobbly and make it feel like the front end is going to fall down and the brake road is going to knock your knee into the ground or none of that stuff. It is purely uneventful unless somebody's going to try and sit on the hood or something while you're doing this so if you've got friends around that tend to do stuff like this keep them away from the car while you're changing your tires
  8. Mendel Leisk
    40,574
    Making some low-rise ramps (say 3”~), rolling the front end onto them, may help you getting a floor jack started on the front/centre jack point.
    my 2 cents: getting the whole car up on jack stands (by raising first the front and then the rear), is the way to go.
    I eschew the scissor jack specd points for jack stands, use more substantial points. This is on 3rd gen, but sim I suspect.
    “Oil change info” link in my signature might help. Again, it’s 3rd gen but sim. If on phone turn to landscape to see sig.
  9. gen2prius
    gen2prius Member
    91
    26
    Sydney, Australia
    i-Tech
    You know it never occurred to me that using a trolley jack can be somewhat challenging. When doing annual inspections, the mechanics at a local garage was able to lift the front without a second thought. May be they have a long reach low profile jack, would have paid more attention if I knew it's not so straightforward.
  10. Mendel Leisk
    40,574
    Gen 2 AND gen 4 front/centre jack points are waaay back, something like four feet? Roughly inline with the front wheels. Gen 3 front/centre jack point is on the lower support beam at the front of the engine bay, only about 18" back.
    Another issue: it seems like the latest floor jacks have a handle that has to be angled up about around 30~45 degrees to start pumping. Which is nigh impossible to do with these way-recessed jacking points. I have an older, cheapie 3 ton jack that starts pushing up the cradle with just 10~15 degrees angle.
    #10 Mendel Leisk, Aug 19, 2022
  11. PriusCamper
    12,048
    4,892
    I think they recommend that jack point because there's no one doing Prius work for Toyota that lacks access to a lift that puts the car up in the air. They're a bunch of executives that haven't ever needed to use a floor jack, let alone get down on the ground just to see under the car. All theory, no practice. Or as my co-worker used to say about our boss back in the '90's: "He hasn't turned a screw in his life!"
  12. 2ndgenbestgen
    22
    usa
    Is it even possible to get a low profile jack into the recommended jack point? I tried, it was jammed up/scraping something on the bottom bumper.
    3 ton Low Profile Rapid Pump® Floor Jack
    that's my jack
  13. Mendel Leisk
    40,574
    Again, low-rise ramps will help on two fronts: allow your jack to roll under there, and give more head room, for operating the handle, hopefully enough. Something simple, say 2 layers of 2x8.
  14. PriusCamper
    12,048
    4,892
    I gave up on my ramps... I have a really cramped space to work in and it's been a huge hassle to keep the ramps from slipping when driving up them and sometimes despite all the extra wood to make the ramp work better I still end up putting pressure on the bottom of the front bumper skirt. So many times I thought I had everything perfectly lined up only to finally get to the top of the ramps and see one of the wheels not perfectly centered but hanging off the edge a litte. Life is way less stressful without those annoying ramps!
  15. Mendel Leisk
    40,574
    I shy away from regular, steeply inclined ramps, the kind meant to raise the car about 6" or more. I almost always use nothing but floor jack and safety stands. But for getting a jack under and functioning (with deeply set-back jacking points), 3" or so lift with a gentle incline can save the day. Made out of 2x material they're very solid and simple. I made sets with ramps at both ends; no risk of "going off the end".
  16. PriusCamper
    12,048
    4,892
    Got some pictures?
  17. 2ndgenbestgen
    22
    usa
    I hate ramps like PriusCamper, but I like the idea of an extra 2-3 inches, just so i could fit my low profile floor jack far enough back
    PriusCamper likes this.
  18. Mendel Leisk
    40,574
    Mine are a little “complex”, give 3.5” lift (see attached). @jerrymildred made some with 2x on the flat; he may see this and post pic.
  19. Mendel Leisk
    40,574
  20. gen2prius
    gen2prius Member
    91
    26
    Sydney, Australia
    i-Tech
    Was going out for lunch, while waiting for my partner to get ready I though I have some time to rotate the tyres. I could position the trolley jack under the front jack point, but there was no room to operate the lever, surprise!
    So I went with plan B, which was to lift one side (both wheels) with one jack, but it was super sketchy because I had to lift the front wheel a lot in order to get the rear wheel in the air.
    So at the end went with plan C, using the spare then swap one wheel at a time. Needless to say my partner wasn't happy by the time I was done.
