Front left turn signal light lens replacement?
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Oct 27, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I have a front left 2010 turn signal light with a broken lens part # 81520-47020
    Can I just replace or repair the lens rather than buy another assembly?
    Thanks
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    I don't think so, you have to replace the whole unit. You should be able to find a replacement on Ebay or Amazon. Then again, you can also get an oem one from the dealer parts dept.
  3. Zteve
    Zteve Junior Member
    2018 Prius
    Thanks nothing. I replaced the bulbs in my turn signals with LEDs. They work fine, very bright. But on the left front, the LED fell out of the socket. I replaced it with the old bulb, but the LED lies at the bottom of the headlight fixture, out of reach until I remove the entire fixture.
