front LSD
Discussion in 'Gen 2 Prius Main Forum' started by flareak, Feb 26, 2005.
  1. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Do we have a front LSD or something that acts like one?
  2. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Oh I see - a limited slip differential! I believe that functionally the answer is yes. There are individual wheel speed sensors and the hybrid system will prevent overspeed or an excessive wheel speed disparity. I believe it is done with a combination of brake application and limiting the power output of the drivetrain.
  3. mswhealer
    mswhealer New Member
    62
    Michigan
    LSD while driving a PRIUS? Actually, I really enjoy it without. I can't imagine LSD in the Prius. It would definitely cut down on the fun of driving and might make my MPGs go down, though others may disagree.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Wouldn't a "real" LSD in *any* front drive car cause squirrelly handling characteristics? I'm assuming by LSD you mean clutch plates with a torque bias spring between them?
    My 1984 Ford F-150 4x4 has a Richmond Gear LockRite - a mechanical locking device that replaces the spider gears - in the rear axle and the factory TrakLok in the front axle. If I try to drive on hardpack snow in 4WD and then try to turn, the front end will do some odd things. It almost feels as if the front axle is trying to steer the back axle.
  5. jtmhog
    jtmhog Member
    151
    If you're concerned about traction, the prius does have traction control which uses the anti-lock brakes.
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    what you need is like the old Glesson TorSen diffy. gears that allow differential action till an obvious loss of traction then lock. Had it in the front diffy of my old 81 Toy 4x4 powered with a turbo charged Buick V6 and auto. Had a TrackLoc in the rear plates and springs. The Gleeson let you steer it under a loss of traction on the front end and really needed it one time when I had it in to the frame on some decomposed granite on an old logging road. Glad for the winch.
  7. Hatfield
    Hatfield New Member
    91
    San Diego, CA, US
    LSD is different from traction control.
    Traction Control is simply the ECU using information from the wheels (usually the same sensors as the ABS system), to back off the throttle when wheel slippage is detected.
    A Limited Slip Differential, unlike a regular differential, limits the difference in speed betwen the left and right driven wheels and is purely mechanical - it doesn't require any intervention from the ECU.
    My Mini Cooper S had traction control, and that wasn't enough. The problem is that when accelerating rapidly, if one wheel broke loose (usually the the right front wheel), the ECU would kill power to the engine, which was not all that desirable. A Limited Slip Differential would have instead limited the dispariity of power applied to the left and right drive wheels. The ECU would have only killed power if both front wheels were breaking loose. It was a big problem on the Cooper S, and I think the '05s all have LSD now.
    Jayman: I don't think LSD makes a fwd car particularly squirrely. I think torque-steer, which is suually caused by unequal length half-shafts, is a much bigger problem. My MINI didnt have any torque-steer problems except on broken pavement, where LSD would have actually helped it a lot.
    I do not think the Prius has a limited slip differential, but I haven't yet encountered a situation where it really needed one.
    Isaac Zachary likes this.
  8. Isaac Zachary
    Isaac Zachary Senior Member
    1,883
    890
    Ya, I kind of wish there existed a torque bias (i.e. Torsen) differential out there for the Prius. If there were one for the Camry/Avalon hybrid I'd take one of those too.
    I do have studded snow tires on and chains in the Avalon. The Prius has cables that came with the car.
  9. black_jmyntrn
    black_jmyntrn Senior Member
    1,300
    340
    2013 Prius Plug-in
    I am actively working on this for my 2013 Plug-in
    Toyota Prius LSD
    using the V CVT
  10. Isaac Zachary
    1,883
    890
  11. black_jmyntrn
    1,300
    340
    2013 Prius Plug-in
    oh fa sho!
