Front parking light replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ucsmfu, Nov 23, 2011.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    Will I have to remove the whole front bumper to change the front parking light bulbs ?
    I noticed that one of them is missing and the other one burnt out.
    let me know
    thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Parking light is replaced on the backside of the headlight. The turn signal you can replace by removing the under cover and reaching up behind the light unit. Pretty easy.
    Robert Holt likes this.
  3. ucsmfu
    1,498
    420
    canada
    really ?
    i looked but i couldn't find any covers ?
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    The drivers side is easy. You simply reach behind/under the headlight assembly where you feel the bulb going in. Gently twist and it will 1/4 or half turn and then the connector comes out with the bulb attached. Pull the bulb out of the connector and push the new one in. On the passenger side you have to remove one bolt to push a hose out of the way, I think it's an air hose but I forget, it's been a while. I've done mine like 3 times now going from the stock to bluevisions and then LED's.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The coolant tank hose needs to be moved to the side.
    Yeah, the passenger side is tough... lots of skin removed on that one.
  6. ucsmfu
    1,498
    420
    canada
    which kind of led light bulbs will be a nice match to the stock LED headlights ?
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I haven't found any LED bulbs that are an acceptable match to the stock LED headlights so I did this.
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    That hose is a definite, but using an 11mm(?) socket to remove the bolt holding the air intake hose(?) and moving the hose up and out of the way gives a lot more room to work with. I always find it easy to locate the socket to remove the bulb, but trying to get it back into place makes me feel like I need to become gumby lol.
    Next time you'll have another option and hopefully save some skin :)
  10. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The owners manual has bulb replacement instructions, including moving a few parts to more easily access the passenger side headlight assembly.
  11. ucsmfu
    1,498
    420
    canada
    i still can't find the spot to replace the front parking light guys ?
  12. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Page 477 in the manual.
    Just curious, you say one bulb is missing and the other burned out? How did that happen?
  13. Colm--
    Colm-- New Member
    Delaware
  14. ucsmfu
    1,498
    420
    canada
    I guess I didn't notice those bulbs before I bought the car, I didn't even know there were parking light there until i came to prius chat, than i looked closely and I saw the left side bulb was missing, and the right hand side, there was a bulb there but it was black, so i assumed it was burnt out ><
  15. ucsmfu
    1,498
    420
    canada
  16. ucsmfu
    1,498
    420
    canada
    will a 3157 60 SMD LED bulb fit the front parking light ?
  17. Tideland Prius
    16,155
    60 SMDs? I highly doubt it. The parking light area is very small.
    Given the number of burnt out front-facing parking lights I've seen on the 2010 taxis, I'd say heat is an issue (or cheap bulbs).
  18. ucsmfu
    1,498
    420
    canada
    will these fit ?
    2 pcs 3157 60 SMD led Dual Switch back White Amber | eBay
  19. Tideland Prius
    16,155
    :shocked: Umm... they're too wide. The opening is a few mm larger in diameter than the W5W bulbs. (Unless the ebay photo is zoomed in but even then, wow that's a big bulb! That might work for places with more room or where the bulb doesn't have to squeeze into a hole like the maplights or door courtesy lights.
  20. ucsmfu
    1,498
    420
    canada
