Front parking sensors
Discussion in 'Gen 3 Prius Main Forum' started by marrat, Sep 4, 2015.
  1. marrat
    marrat Junior Member
    47
    Netherlands
    I have a 2010 Prius, the highest trim model here in the Netherlands. What I can't figure out is whether I have front parking sensors or not. I thought the small circle in the front was a parking sensor (marked in the image), but nothing beeps when I walk in front of it (when car is in D). So if that thing is not a sensor, what is it? If it is a sensor, could it be disabled somehow? The car in the image is not my car btw.
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The "buttons" or "rivets" in the bumper cover are for the sensors. If you have Intelligent Park Assist there is a button on the lower dash to the right. On the camera display below the image there are two vertical red lines that are aligned with the ends of the rear bumper and a line drawing of the car. Sorry, I couldn't find a photo.
    If you actually use IPA several targeting overlays are displayed.
  3. marrat
    47
    Netherlands
    I do have IPA, but I used it once and gave up on it. It works, but it's very slow. So the front sensors can only be activated when I use IPA? Or are they activated when I push that button? I saw the button, but I never used it since the IPA starts when you put the car in reverse and select a parking space on the screen.
    In my previous car, the sensors were on when I put the car in D and the car was below 20KM/h.
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    The front sensor is only for IPA and nothing else. If you want front parking sensors to work in D you'll have replace them with aftermarket sensors and control module.
