Front right tire not connected to steering after tiny bump into a pole..please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mehera, Nov 26, 2019.
  1. Mehera
    Mehera New Member
    Pasadena CA
    My insurance is not great and now my 2010 Prius is not drivable. I lightly hit the right side bumper into a pole. The car seemed fine with just a scratch and I drove home. The next day the right wheel was not responding to the steering. I took pictures for the insurance and found a cord about an inch in diameter hanging loose so I'm assuming somehow that disconnected the wheel. The insurance is taking their good old time and I'd rather just fix it myself. Any suggestions as to what happened?
    49,430
    when you turn the steering wheel all the way from one side to the other, the tire never moves?
    that does not seem like a project for a novice. does the cord have a plug on the end?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,160
    2,208
    Taylors, SC
    Sounds like the last time the car got an alignment; the technician failed to tighten the connector clamp between the tie rod and the tie tie rod end on the right side.
    Bumping the curb loosened and likely disconnected the link.
    I had a lady friend who had this happen to her Lexus RX300.
    It may not be an insurance responsibility, if it was a mechanical failure.
  4. ChapmanF
    15,560
    Can you attach a photo?
    Is your avatar a photo of the affected knuckle, or just some other random photo?
    It's a little small, but there are things I'm not seeing where I would expect the ball joint to be attached.
    Hmm.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,209
    5,902
    Columbia, SC
    Pretty slick idea to use the avatar to post a photo. The shaft that screws into the tie rod end has snapped right where the locking nut snugs.
    The outer tie rod is still connected where it belongs on the tire side. Just the inner shaft snapped. The broken portion should be able to be removed easily from the rod end. A $50 part and a couple hundred to install, give or take a bit..probably.
    The broken part looks like this. The entire steering assembly uses threaded shafts and locknuts.
    Toyota Prius 2010-2015 Inner Tie Rod 4 Pc. Set-Left or Right-IN STOCK-2 Tie Rods | eBay
    #5 TMR-JWAP, Nov 26, 2019
  6. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Looks like the tie rod broke. If you hit a curb hard enough to break the tie rod there is likely to be other damage. You will find this out when you go to perform an alignment.
    Be prepared to replace some or all of the following items:
    - Strut
    - Lower Control Arm
    - CV Axle
    - Knuckle
    - Wheel Bearing Assembly (sometimes this will not show up immediately, but hard impacts will trash the bearing assembly)
  7. TMR-JWAP
    6,209
    5,902
    Columbia, SC
    I'm still trying to picture this entire scenario.
    Lightly hitting a pole.
    Driving the car home.
    Next morning, wheel doesn't respond.
    I absolutely have to believe the shaft wasn't broken prior to driving home. Seems the steering would be acting a bit funny if it was. :confused:
    Or maybe that drink during dinner was a bit stronger than thought...….just kidding (hopefully)
    The Critic likes this.
  8. bisco
    49,430
    she's toying with our affections fella's...
  9. Mehera
    Mehera New Member
    Pasadena CA
    I will try the steering and see if it does. The photo of my avatar is the cord. Thanks
  10. Mehera
    Mehera New Member
    Pasadena CA
    No drinking but I was tired. Still the car drive home fine. The next day the wheel wasn't responsive. Terrible week for car problems. Everyone is telling me Monday. I put the photo of the problem as my avatar. Thanks for responding
