Front right turn signal light not working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CARSFAN4, Feb 6, 2023.
  1. CARSFAN4
    CARSFAN4 Junior Member
    62
    Los Angeles
    2015 Prius c
    2015 Prius c front turn right signal light not working. I checked the bulb, was in good condition. I also tried to replace it with a similar yellow bulb and it still doesn't work. In the same time the exterior mirror turn signal doesn't work.
    Will this be an electrical wire problem or maybe the fuse?
    But my front left turn signal light works on both the low front light and the exterior mirror signal light. Anybody can help me???
    Thanks
  2. Leadfoot J. McCoalroller
    7,984
    7,462
    Pennsylvania
    2018 Prius c
    Check the headlights and the hazard flashers to fill in the blanks.
    If both low beam headlights work and you have the other lights blinking with the hazard switch on then the fuses are fine and this is wiring, connector or bulb.
  3. vvillovv
    vvillovv Senior Member
    4,320
    1,505
    NY
    Is the driver side rear turn signal light also not working? Are all passenger side turn signal lights working? Are both of the blinker indicator lights on the dash working normally?
