front seat mod
Discussion in 'Gen 2 Prius Accessories & Modifications' started by rufuslyon, Sep 8, 2018.
  1. rufuslyon
    rufuslyon Junior Member
    los angeles
    I’m pretty sure 99.9% of gen 2 owners can agree that toyota’s engineers took inspiration from medieval torture devices when designing our front seats. Here is a quick and simple mod you can do to make your seats a little bit more bearable for longer trips.
    Tools required:
    14mm socket
    dikes/wire cutters/diagonal cutters
    pliers
    90 degree pick (optional but highly recommended)
    step 1. slide seat all the way back and remove two 14mm bolts from front of seat. 36A37BB2-0392-45A9-9ECD-BA9CD59177D6.jpeg
    2. disconnect connectors from bottom of seat. 7F2D8E12-BBFB-4643-B2B0-9C911A5421EA.jpeg
    3. slide seat all the way forwards to gain access to rear bolts. remove plastic cover and remove. 935FC24E-AEAA-483C-8C6E-CE07DE267FCD.jpeg
    4. remove seat and unhook seat back cover/flap and lift out of the way. D84F5EC4-50CF-4BBB-8617-B6D15FDED17E.jpeg
    5. use your dikes to grip the hog rings and twist until it seperates enough to remove. repeat for all 3 hog rings A26FC3FE-D587-4127-87E3-A4701D61B229.jpeg A8157602-C82D-43E3-B467-BAECB69EB3D1.jpeg
    6. lift seat cover just enough to gain access to the seat back springs. each spring end is a 90 degree bend and hooked into a plastic ring on the side of seat. remove each end from plastic ring (4 total). 87B485A3-0095-4838-96ED-FD5DE1052A62.jpeg
    7. slide seat cover back down and secure hog rings. (this is where the 90 degree pick comes in handy.) use your pliers to pinch them back together. D7D1F8DD-BB43-4C7B-82D5-A94588DE3E89.jpeg 5963C831-A279-4CEB-95FC-30B8780531F2.jpeg
    8. follow steps 1-4 in reverse order to reinstall seat.
    9. enjoy refreshing beverage
    Priusjames and bisco like this.
    49,504
    welcome and well done!(y)
    but what was the mod?(n)
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Yeah, What was accomplished?
  4. rufuslyon
    los angeles
    the mod is releasing some spring tension on the seat back so it doesn’t break your back on long trips.
    it’s also an affordable (free) option for those that don’t want to pay for the cushioned seat covers i’ve seen advertised in other threads
    preventing back pain while driving and saving my wallet from equally painful chiropractor bills
    #4 rufuslyon, Sep 11, 2018
  5. rufuslyon
    los angeles
    I realize my last response could come off as a bit snarky and I don’t want to get off on the wrong foot or get banned after my first post :unsure: so let me try to explain a little more clearly.
    The purpose of this modification is to release spring tension in the seat back so they’re hugging you instead of constantly pushing you away. Majority of new/late model cars are/were sold with super stiff seats so they maintain that “factory fresh” feel 5–10 years down the line. For those of us with chronic back pain the seats might as well be medieval torture devices.
    We’re not driving Cadillacs or Rolls Royces so you shouldnt expect day and night results by doing this but it should help on those longer drives. If your seats don’t cause you any discomfort then that’s great! (y) I wish I could say the same but unfortunately mine do and I don’t feel like spending the money I’m saving on gas on aftermarket seat cushions.
    This is actually very popular mod among mid 2000s - mid 2010s subaru owners. The only reason I was able to finish my cross-country road trip in my old outback and not feel like Batman after fighting Bane was because of doing this mod half way through my trip.
    Sapphire Dragon likes this.
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    I, and I would think others, still have problem understanding the modification. You have a good explanation on how to do the mod. But not for what it does to what part of seat. Or for how or why it would help.
    If this mod is done for seat back wouldn’t it just remove the support from center of your back and lumbar? Wouldn’t this just cause your back to be bent into curve? Isn’t that the main cause of back pain?
  7. bisco
    49,504
    thanks! i had a feeling it was releasing the spring tension, but had never seen any type of mod like that before.
    it sounds like something you have to try, to see if it helps.
    most people stuff pillows and towels for lumbar support, which often doesn't help.
  8. rufuslyon
    los angeles
    in theory yes, you are correct but imagine yourself jumping off of a 10ft wall. Which would you rather land on? A mattress/foam cushion that would soften your landing by absorbing a good amount of your kinetic energy or a slab of concrete that would reflect it all back to you.
    eveything in a car moves, especially the driver. so having a car seat that’s capable of absorbing some of your energy instead of reflecting it right back into you is very beneficial for long drives.
    i should’ve noted in step 6 that there are 2 on each side so anyone that decides to modify their seat can remove the top 2, bottom 2 or all 4 depending on their specific needs.
    exactly what i did when driving through middle of nowhere texas and i can tell you that it didn’t help:cry:
    #8 rufuslyon, Sep 13, 2018
  9. KostyaSha
    KostyaSha Junior Member
    Belarus
    Additionally you can put big washers under the front bolts (~4mm in summary). This will change degree to more comfortable.
    PS i personally solved prius 20 seats issue by installing lexus electric seats with climate control and adjustable steering column like in 30/40/45. :whistle:
