Front shocks fitted
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SnT08Prius, Sep 27, 2021.
  1. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    It took just 2 hours to fit the new front struts. So now all 4 corners have been updated.
    The 350 mile round test drive really showed how bad the car had become as it just ran over all the bumps and tackled the cross winds at 11,000 ft on Bear Tooth Pass.
    The trip on fuel seemed to be very positive.
    Bozeman to the peak (10,943) retuned 32 mpg
    Bear tooth pass peak back to Bozeman via Yellowstone 68MPG
    Overall 50.4 that had 120 miles of freeway, several huge climbs and some slow tight corners with rolling hills.
    Next is the ball joints, link pins and tie rod ends. :)
    privilege and SFO like this.
  2. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Ball joints wore out? How many mi
  3. privilege
    privilege Active Member
    659
    169
    Birmingham
    which struts/shocks did you order ?
  4. SnT08Prius
    158
    187
    Bozeman, Montana
    I got them from Detroit axle - seem to be very good fit - went right in for both front and rear.
    privilege likes this.
  5. SnT08Prius
    158
    187
    Bozeman, Montana
    368,000 miles and yep I think they are done :)
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any updates on the shocks/struts?
    Which brand(s) are you considering?
  7. SnT08Prius
    158
    187
    Bozeman, Montana
    The struts made a huge difference to the ride - well worth the effort!
    The ball joints just came from Ebay with links and tie rods for cheap - like $60. Had the workshop fit and do wheel alignment. No more rattles over the rough roads. For a car thats done 369,000 miles very happy. The battery with the 5 replaced cells is holding up great on early morning starts too!.
