front speaker options
Discussion in 'Gen 3 Prius Audio and Electronics' started by summit123, Nov 12, 2010.
  1. summit123
    summit123 Junior Member
    96
    MA
    An extensive search didn't seem to come up with any relevant threads, so here is my question:
    I spent 3 hours yesterday breaking my back replacing my driver's side door speaker. I had order a Kenwood HU and 4 speakers from Crutchfield to replace the door speakers. Just like most people have commented, the factory door speakers are riveted in. Getting those out were a complete PITA. Then I was forced to drill new holes in the door to mount the adapter plate that came with the speakers, as the screw holes on the adapter did not fit the rivet locations. (Crutchfield was very disappointing as they never indicated the necessary mods required on this car. They're always touting that they have the exact fit adapters for car equipment, but it certainly wasn't the case this time). I had ordered 6.5" speakers as Crutchfield had indicated that those were the only ones that could fit in the doors.
    When I finally finished the install, I did a quick sound test. It sounded absolutely awful, not even half as good as the original cardboard speakers. Now I know that part of it is that the factory stereo is weak so isn't able to power the new speaker adequately, but the bass was completely missing. The original speakers look like 6x9s, so what is the reason that I cannot replace them with new 6x9s?
    The other question is, should I be concerned about corrosion at the new holes I drilled. I know that car steel are galvanized, but I think that the galvanizing process usually occurs after all the necessary holes are drilled/cut in the parts beforehand so the holes themselves are galvanized. With a new freshly drilled hole, that part of the steel is no longer galvanized.
    I am now completely regretting changing the speakers. I am hoping that it will sound better once I replace the HU, but given the downsize on the front speakers and the resulting penalty on the bass, I may be forced to consider adding a sub.
    One final question, is there a way to remove the crossover feeds signals to the squawker? I would think that I wouldn't need any sound from them now that I have 3-way door speakers, and having this factory crossover is probably causing me to lose the mid and highs to the Kenwoods.
    thanks in advance for any help on this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What kind of speakers where they (brand)? Are you sure you got the polarity of the wires correct? What was the impedance of the new speakers?
  3. summit123
    96
    MA
    Yes, I got the polarity correct. I used the Crutchfield quick-connect speaker harnesses. The black and white wire metal clips of the harness are actually different sizes so it is practically impossible to get the polarity reversed unless you force it in.
    These are the Kenwood KFC-1662S. 4 ohms. Is the factory stereo not rated to handle 4 ohm speakers optimally?
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    No I believe the II has standard 4ohm speakers so you should be OK there.
    I have not replaced my speakers myself. After upgrading my HU, I found there really wasn't a need. I was just checking on the common problems. However I would like to replace the squawkers with a nice component mid/tweet.
    Others will likely have more suggestions.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You've added a few good points that maybe weren't clear from all the posts...
    Removing the speakers is a pain - unless you have the correct drill bit (size) - with the correct drill bit, they pop out in like 3 seconds.
    Adapter plate - the one I got was flimsy ABS plastic (if I open the doors again, I'll make my own out of wood). Again, mounting it relative - if you have a good drill, and drill bit, and 4 screws (buy the self tapping ones at Home Depot/Lowes, and drill a tiny hole), it isn't that hard.
    I have a previous post talking/pics about my installation - I cut out the Molex connector (factory one) on the speakers, and reused it for the replacement. Then solder the wires that went to the old speaker to the new one. Makes it easy to remove, and a clean install (no wire cuts).
    You have a huge issue with the factory vs extra speakers (Tweeter vs mid/bass). The Xover is on the Squaker/tweeter. You now have two speakers with different sensitivities (one louder than the other - which goes up as volume goes up).
    You have a few options:
    1. Return the speaker, and buy a component 'set' - with crossover (replace squaker also). I've run Infinity Reference ~$!40 (they moved to the rear after--> ), and MB Quarts ~$125 (IMHO better than infinity in our car).
    2. Look at the 'sensitivity' of your speaker, find a matching tweeter, and a crossover for the set. Then roll the dice...
    3. Put the old ones back in...
    You really need a speaker up top as highs are pretty directional.
    I'll add here - if you are doing this - just buy the Dynamat large kit (or I have posted lower cost alternatives), and since the door is open, line it with soundproofing. I'm not sure I hear a difference - but it sounds more like our Lexus now when I close the door:rolleyes:
  6. summit123
    96
    MA
    was very curious about the squawker the other night. I remember the posts about removing the cover, but it involved removing the A pillar plastic cover, and I wasn't about to have the airbag explode into my face. I started digging around the squawker cover, and it actually almost came out entirely. The only part that wouldn't come out was the front outer corner where one tab was tucked under the A-pillar cover. It was still enough that I could get a good look at the squawker and access the 10mm nuts. Will remove the squawker later this week and try out the Kenwood component tweeters I got. I am hoping the factory crossovers will be close enough because I don't want to do any more surgery on the car than I have already.
  7. rrolff
    1,610
    246
    So Cal
    The A pilar is actually very easy to pull...
    The crossover is built onto the squaker (when you pull it, you'll see).
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Which Kenwood component tweeters did you get (model)?
  9. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
  10. summit123
    96
    MA
    I had gotten the Kenwood 709PS. I popped in a tweeter in the driver's side and it sounded quite nice.
    I did see the built-in crossover in the factory squawker on the underside of the speaker. The wiring harness looks like it is pulling the signal/power from the headunit to the squawker to the door speakers. There are 4 wires in the wiring harness, 2 pink and 2 purples. One of the pink and purple is the (+) and (-) from the HU(the inner pink and outer purple wires(this will make sense if you are actually seeing the harness with your own eyes. When I disconnected the squawker from the harness, I initially lost sound to the door speaker. I stuck short wires connecting the two pinks together and two purples together and that restored the sound to the speaker. When I wired the inner pink and outer purple wires to the Kenwood tweeter, I was able to get sound from the tweeter.
    If I remember correctly, the pink is positive and puple is negative. When you look on the underside of the squawker, the pink is closer to the (+) terminal of the squawker and the purple closer to the (-) terminal, which was why I hypothesized the pink/+ and purple/- associations.
    I had a idea of flush-mounting the tweeters to the squawker cover. I may eventually cut out a round hole on the removable squawker cover on the dash so that it will be able to flush-mount the tweeter. The tweeter grill of the Kenwood and other brands all seem to be black. I think the tweeter will blend in well enough to the black/dark cover and seem unobtrusive enough that it will reduce the chance of theft. Personally it seems to be a more ideal/safer place than mounting in the area by that little glass triangle right in front of the front doors as they stand out quite a bit from a passer-by. The Kenwoods also have tiltable tweeters so even when they're flush-mounted onto the squawker cover, I should be able to redirect a little towards the driver for better imaging. The most challenging part is probaby dissecting that harness. Anyone know if there is a harness adapter similar to the standard door speaker harnesses for the squawker area so I can preserve the sound to the door speaker without too much Macgyvering?
