Front Splash Panel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by griffibaby, Oct 5, 2017.
  1. griffibaby
    griffibaby Junior Member
    30
    US
    Hey Everybody,
    The panel that attaches to the front bumper is partially pulled off. I have glued the panel onto the bumper several times and it lasts for awhile
    I've been told it can simply be pulled off, that it is not all that important.
    There is not much of the panel to glue.
    Your thoughts?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    yes or can be zip tied
    49,508
    if it's right in front of the radiator, it might help prevent rocks from bouncing up and causing a huge expense.
  4. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Raytheeagle likes this.
  5. Mendel Leisk
    38,736
    Do it right? Gluing it, sounds like you're missing some or most of the fasteners. Get on a Toyota parts retailer site, see what's involved, get the proper fasteners, decide what can be refurb'd, or has to be replaced.
  6. griffibaby
    30
    US
    Will do, tomorrow! Thanks!
    Hmmm. Yes the panel goes from drivrt's side to passenger's side, so probably protects he radiator.
    I'll not try to repair this again myself. Although I am so tempted - just the competitve nature in me.
    Thanks!
    #6 griffibaby, Oct 5, 2017
  7. bisco
    49,508
    i drilled holes in my sons camry and wired it all together.
  8. Markee
    Markee Member
    325
    50
    South Florida Broward County
    Buy a new panel off ebay and replace it
  9. Mendel Leisk
    38,736
    It's held on by a mix of:
    1. 4~5 bolts into tackwelded nuts in the frame.
    2. 4~5 screws into nylon inserts in the bumper.
    1. One plastic push-in style anchor, at centre.
    It's those semi-circular pockets at the back that snag and abraid:
    Close ups:
    Fiberglass mesh and two-part epoxy applied:
    If it's too far gone, I'd go for that linked replacement part, very reasonable price compared to up here. You'll like need to get some replacement screws, the nylon inserts, and/or the plastic push-in fastener. The bolts are probably in place, if they haven't rattled off: it's more likely the plastic tore free.
    You can do an assessment without even raising the car, but rolling it onto ramps or using a floor jack and safety stands will make it much easier.
    danlatu and Raytheeagle like this.
  10. griffibaby
    30
    US
    Hi Mendel,
    Thanks so much for the detailed response. I believe I csn do this with another set of hands. Thanks again for saving me big bucks. I work in social services so every penny counts!
    Cathy
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Years ago when mine broke off it happened to drop and drag on the ground for the final time about 5 mins. from my Toyota dealer. I drove into the quick lube since I was late for work. The mechanic says this cheap, some swear words, plastic thing is worthless. He cut it off and threw it in the garbage and I was on my way LOL.
  12. Mendel Leisk
    38,736
    Trouble with that: the underpanels are lapped, kind of like shingles: each one sort of shelters the one aft. Pull off that front piece, and the main engine underpanel is more vulnerable, and the engine bay is partially open, cools faster, and so on. But hey, just drag it some more, pull into quick lube, more swear words, pronounce that one worthless too, lol.
    jerrymildred likes this.
  13. danlatu
    danlatu Senior Member
    533
    1,348
    maryland
    Drill holes, zip tie or fix with Duramix. Auto body shops use this to fix bumper tears and cracks. Area has to be sanded and cleaned and prepped with an adhesion promoter. If you cut any corners on prep the product will not sick properly.
    Screen Shot 2017-10-08 at 9.35.23 AM.png Screen Shot 2017-10-08 at 9.48.40 AM.png
