Front Strut Replacement technique
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JayHart, Jul 1, 2016.
  1. JayHart
    JayHart Junior Member
    georgetown,ma
    I watched the vid that showed a huge amount of cowl/plastic/metal removal to allow replacement of the front
    struts. I bent a 14mm ratcheting wrench to an offset and I can reach and loosen/tighten the 3 nuts on each strut.
    Why would one go through all of that work/hassle when you can possibly just do what I suggested.
    Am I missing anything?
    I needs front struts but the 800-950 quotes due to disassembly is a lot of $$.
    Thanks,
    Jay
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Can you reach those nuts with a moderately offset non-ratcheting box-end wrench?
  3. JayHart
    georgetown,ma
    I will post a few pics
    Jay
  4. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    THAT would save quiet some time/
  5. JayHart
    georgetown,ma
    I got all 3 loose enough to finish by hand. The front 2 just used a long straight box end to get enough torque.
    The back one needed an offset/bend. I know I will not be able to get a torque wrench for reassembly.
    I'm ok with that. Any one else try this approach yet/before?
  6. ChapmanF
    15,614
    If you have a way to fit a socket or driver to the other end of your offset tool, and you measure the effective length of your tool (from the center of the box going over the strut nuts/bolts to the center of the socket/driver at the other end) and the effective length of your torque wrench, algebra can give you the proper setting on your torque wrench to give you the specified torque at the nut/bolt.
    -Chap
  7. JayHart
    georgetown,ma
    A = offset wrench center-center length
    B = torque wrench center-pivot length
    T = desired torque
    mT = modfied torque (as read on torque wrench)
    mT = T * B/ (A + B)
    so if A & B are roughly equal then the mT is about 1/2 of T.
    Seems reasonable.
    Thanks
    I'd like to hear if getting these 3 nuts off/on of each strut is all it will take up above
    to get the strut in/out.
    Seems like this should do it????
  8. Patrick Wong
    18,200
    6,474
    Yes, that is correct.
    However, once you have the strut out of the car you have to remove the large nut at the center of the strut top mounting bracket, after putting the spring compressors on. This is not so easy to do if you don't have a large vise to hold the strut.
    Having done this job several times on my Classic and 2G Prius vehicles, I have found that it is much easier to remove that large nut by loosening it 1/4 turn while the strut remains in the car. Obviously you will not be able to do that without having free access to the top of the strut, which implies the windshield wiper motor and tray are first removed for such access.
