Front Strut Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jkan2001, Jul 17, 2017.
  1. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Does anyone have a write up or video about how to change the front struts on a 3rd gen prius? Also curious if you have to take off the windshield wiper arms/motors to get to the strut towers. If so is this a good time to go ahead and change the spark plugs when it's all apart?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    makes the job easier with cowel off and might as well do the plugs
  3. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Do you have to remove the cowl and wipers etc to do the struts in order to reach the bolts at the top of the strut tower or no? I'm having a mechanic do it and wondering if it's worth it to pay him a little extra to do the plugs if he has to take the windshield wiper cowl and stuff off anyway.
  4. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I remember when I put on my strut bar I had to remove the cowl in order to get to the bolts at the top of the strut tower. So If your car needs new spark plugs, might as well go ahead and have them changed out while at it.
    Jkan2001 and Raytheeagle like this.
  5. Victor E. Sasson
    Victor E. Sasson Junior Member
    Our 2010 Prius has more than 83,000 miles on it, and when I hit a pothole recently, I literally heard a boing from the right-front strut, and the car seemed to bounce up and down a couple of times. So, it seems I should replace the front struts, but what about the shock absorbers in the rear? Can I leave the originals in? We're also going to do all four disc brakes. At the dealer, I am not a do it yourselfer (but I looked at a video and it looks challenging). Dealer in New Jersey doing brakes on each end for $259 each. No price for struts on website. Any info on that price?
  6. Victor E. Sasson
    On YouTube:
    Scarface2005 likes this.
  7. Patrick Wong
    18,200
    6,474
    Since you characterize yourself as not DIY, the front struts are not the place to start as the difficulty is moderate and requires access to the proper tools. I would replace the rear shocks as well.
    You asked about parts pricing. Here is one example of a Toyota dealer parts website:
    Front Suspension for 2010 Toyota Prius | AutoNation Toyota Gulf Freeway
    At minimum, the front struts, the top rubber insulators (which is the pleated cover) and the strut mounts should be replaced for a complete job.
    At the rear axle, the rear shocks should be replaced while the other suspension parts probably can be reused unless damaged due to rust, impact with a curb, etc.
    #7 Patrick Wong, Aug 12, 2019
    Raytheeagle likes this.
  8. Jim Swart
    Jim Swart Member
    49
    37
    Portland, OR
    If you are not DIY inclined but still want to change the struts yourself consider buying a compete assembly with new mount and coil spring. Then its just a matter of removing the old strut and bolting in the new one.
    Scarface2005 and mikey_t like this.
  9. Victor E. Sasson
    I think you have to remove the cowl and windshield wipers to get to the top of the struts. I had the job done at the dealer, replacing struts, bearings and other parts, but didn't change the rear shock absorbers. After the struts, bearings and other parts were replaced, the car also needed a 4-wheel alignment.
