Front suspension popping. Replaced strut. Noise still present.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Mar 18, 2016.
  1. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    So I replaced the front strut and the popping is still there. When I removed the old strut it seemed like that would be the problem as there isn't any play in the ball joints and tie rod end.
    Anyone else experience this or something close to it?
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Is it popping when you turn the wheel? Does it happen at low speed while you are turning the wheel quite a bit (e.g. maneuvering in a parking lot, into a garage)? If so, I think you are hearing "spring bind." It's fairly typical on coilovers, but I also heard it on my car when I had the factory springs on as well.
    edthefox5 likes this.
  3. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Last time I had a popping sound in the front end you could only hear it when turning. Turned out they had to replace left front axle assembly because the boot got knocked off , leaked all the oil out and ruined the bearing. Thank God for extended warranty .
    ScottHz likes this.
  4. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Yes, CV joint would be my other guess. Probably not tie rods or ball joints as you would probably feel more vibration as you are driving.
    solrunner and lar.smith42 like this.
  5. yeldogt
    yeldogt Active Member
    810
    313
    NE
    how many miles?
    Did you only do the one side?
  6. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Nope. Anytime I'm on the road, no matter the speed, going straight or turning. A bump still bring the sound out.
    No. It isn't a half shaft. It only happens while driving, going over bumps in the road.
    Ironically, earlier in the day I had replaced one of my sister's half shaft on her car.
    204k. Currently, I didn't know I needed boots as well. I thought it came with them. And only one place had ONE in stock. So I wanted to get rid of the sound, thinking it was only the strut. But I ordered another one to complete the project next week.
    Did everyone notice the old strut wasn't extended out? Never seen that before.
    ScottHz likes this.
  7. yeldogt
    810
    313
    NE
    at 200K + ... they can't have much life in them.
    ScottHz likes this.
  8. solrunner
    solrunner Member
    114
    37
    Reston, VA
    When replacing struts it's recommended to replace the strut mounts, too. That's the top part where the strut mounts to the engine bay. Also you're supposed to replace struts and shocks in pairs. Left and right at the same time.
    ScottHz likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    99% of coil over popping is usually spring bind. Where the spring is not seated properly on the strut mount. The spring may be worn out and not seating properly. Try spraying some lubrication where the spring sits in the lower mount.
    How did you get the spring on the strut when you replaced it? Its pretty hard to diy that and get the spring on correctly. And like the other poster said the top bearing assy is just as important as the strut. You won't believe how much harder it is to turn with a 200K mile bearing assy. Really hard on the rack.
    But its a moot point anyway as at 200K + miles the whole front suspension is pretty whipped.
    ScottHz likes this.
  10. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Well, I did immediately order strut mounting plates for both sides along with the other boot that nobody else had in the the following morning. I used an AutoZone rental to compress the spring. But I've got a much nicer tool coming when I redo the driver's side and the passengers side for the first time.
  11. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Its a real pain and very unsafe to compress the spring yourself. Tough job. Most auto parts stores have a service to do that now.
    Its hard to get the spring seated in the perches correctly when your diy as there's no fixture to hold the whole assy while compressing the spring.
  12. mypriuscious
    mypriuscious Member
    205
    70
    Cincinnati, Ohio
    Yeah, it's like I said. I've got a nice tool for that.
  13. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Sway bar end links are common, especially given the mileage on the car.
    SM-G900V ?
