Front Suspension Upgrade, anything else? Spring Compressor?
Discussion in 'Gen 3 Prius Technical Discussion' started by black_jmyntrn, Oct 12, 2021.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    Can someone link me to a spring compressor that you've used on a Prius? I have all of these parts plus new heavy-duty springs with a lift, Stabilizer Bar End Link, and Tie Rod End. Is there anything else I should replace while all the other installs are going on?
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    rent one for free at autozone /
    just leave a deposit /
  3. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    I want one of my own for future installations
  4. amarino
    amarino Active Member
    139
    102
    99
    Note: My experience with these is based on old BMWs from the 80s and 90s. I haven't tried this on anything newer yet.
    At AutoZone the rental will be something like these. I don't like it as its too bulky on the top and bottom. I have a set and I hate them, always gets stuck around the top hat for my old BMWs.
    MacPherson Strut Spring Compressor Set
    Something like this style looks better and less bulky but I haven't tried one personally yet.
    And lastly something like this would be even better since you don't have to worry about compressing both sides evenly since it wraps around. I also haven't used anything of this style personally but it looks like the easiest and best.
  5. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    amarino likes this.
  6. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    update, those spring compressors are good, the only complaint is you can't use them to install the front strut/heavy-duty spring plus the 1.5 lift. You need an internal spring compressor.
    lastly, the kyb excell g top mount only has a little soft plastic part included. The stock has almost a mount for the top of the spring and another mount on top of that.
