Front Tire Thudding feeling
Discussion in 'Gen 2 Prius Main Forum' started by Silver Surfer, Jan 26, 2010.
  1. Silver Surfer
    Silver Surfer Junior Member
    38
    Asheville
    While driving at low speeds up to about 30 MPH, I feel what can only be described as a light thudding from the left front end through the floorboard. It cannot be heard, and also cannot be felt in the steering wheel, but both driver and passenger can feel it in your feet from the floorboards.
    I brought it in to the dealer who told me it was cupping. They rotated the tires and sent me on my way but it is was still there. I brought it back in and they checked again. They said the bearings and front end checked out OK and that this rotated tire probably had a soft and/or hard spot in it.
    Now the thudding is even worse after this second check.
    It is not a sound, but just something you can feel through the floorboards.
    Anyone else have a problem similar to this or advice on what it might be? It is really annoying until you get past 30 MPH.
    Thanks
    Jim
  2. Patrick Wong
    18,200
    6,471
    Were the tires also balanced when they were rotated?
    If yes, then the diagnosis sounds reasonable. I recently had a similar problem with my 2004 (except the tire noise was quite noticeable) and ended up buying four new tires although the existing tires were only 50% worn. The car used to sound like a 4x4 equipped with all-terrain tires and there was substantial vibration at speed. Now all is quiet and smooth again.
  3. Silver Surfer
    38
    Asheville
    I don't believe they balanced them, just rotated. The tires have 25K on them. The wear bands are just becoming visible very slightly.
  4. Patrick Wong
    18,200
    6,471
    Well, it sounds like your tires are fairly worn, so you may want to consider buying a new set now.
    Or if you want to try to get more use from those tires, then you could have them balanced to see if that helps. Good luck.
  5. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    i have heard that noise on my GII recently at low speeds (15mph or less).
    it's almost like a "bump....bump...bump"
    i have about 35K miles on my 2nd set of tires (Goodyear Weatherhandler from Sears, got a good deal on them at the time).
    after reading abt your problem, and knowing abt what noises i hear on mine, i am convinced that it's a tire noise.
    now...i run my tires at 44psi fronts, 40psi rears.
    so, i believe that it's an uneven wear or slight imperfection in the tire that is noticeable at high psi.
    although my tread has 20K left, i may consider new tires prior to that.
  6. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    I have recently had a similar problem. The wheel will balance and everything checks out, but thumps at low speeds. At road speed it seems to smooth out, but is definitely noisy...
    After replacing one tire at a time (with the spare), I found the culprit. Talking with a knowledgeable "tire tech", he believes that it is the result of belt separation internal to the tire. It is often cause by curbing the tire or potholes. (Lord knows, we have plenty of those here).
  7. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Jim, If your tires are cupped (probably a result of running out of balance) you will feel what you describe at low speeds. It won't be as noticeable at highway speeds. Once cupped, balancing will not correct the problem; although, moving the cupped tires to the rear may make it less noticeable. That's assuming the tires moved to the front are not also cupped.
    By the way, did the dealer take the time to show you that you can pass you hand around the circumferance of the tread and feel the cupping? If not, try it. Then take the suggestion to replace the tires.
    Probably the first thing you will notice is how quiet the car is at highway speeds and the "thudding" will be history.
  8. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Often you can feel belt separation in a tire just by running your hand over the tread.... which you can do while the tire is still on the car, but you will need to wash your hands after. You can feel the un-roundness of the tire.
