Front Tires going bald F A S T
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Karen E, Nov 13, 2014.
  1. Karen E
    Karen E Junior Member
    Noticed my two front tires went bald very quickly after my last regular service and wheel alignment at the dealership 2 months ago. It's really scary..my car lost control for a couple seconds last week on a rainy day. Went to have the dealer inspectors check it out and they were shocked at how bad the tires looked. Has anyone else had this problem???
    51,154
    probably make a fortune. just look at all the carp they sell in auto parts stores that don't actually do anything. no offense, but looking through your 13 posts, i think you have a small problem with over reaction. i'm sure everything will be fine.
    #2 bisco, Nov 13, 2014
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Buy new tires and never use a dealership for wheel alignment, there are speciality shops for that. After that is done drive the car a couple hundred miles and check the tires for uneven wear.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The dealer lowered the pressure on the tires. Not to mention, the OE tires are pure crap.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,595
    5,893
    Texas Hill Country
    Some have had the problem at 35k miles with Toyo tires. What kind of tires did yours have (several OEM)? How many miles does it have? Were the tires rotated every 5k miles per requirements?
  6. Emcguy
    Emcguy Member
    176
    29
    Australia
    My v tyres are bald at 37000 kilometres. That's right, kilometres!
  7. Mendel Leisk
    40,582
    The "smoking gun" seems to be the dealership's alignment job. The only thing adjustable is toe-in, I think. So strong possibility they messed that up.
    Just to calm down a bit: how much tread is currently left on the rear tires, to compare? And how many miles on this set of tires?
  8. Okinawa
    Okinawa Senior Member
    1,333
    317
    You are right, OE tires are pure crap, just worthless.
  9. Mendel Leisk
    40,582
    I do not know, our OEM Michelin Pilots seem ok. :rolleyes:
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    It is a hit and miss. I still have my OE Toyo Proxes at 45K.
  11. Okinawa
    1,333
    317
    Michelins are an exception. They don't make a bad tire to my opinion.
