Front Turn Signal Lens Replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CClmos23, Sep 5, 2012.
  1. CClmos23
    CClmos23 New Member
    Does anyone have any experience replacing a cracked front turn signal lens? Or know where the part can be found? Thanks in advance.
  2. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    Get under bumper - remove bulb, remove the screws holding it in - then reverse the process for re-installation.
    Probably need to contact Toyota and get an OEM part unless you get lucky and find one on ebay. Until a bunch of Prius C's start getting wrecked there are not a lot of parts available from salvaged vehicles. Good luck!
