Front windshield washer: do they fail?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blaisep, Jun 13, 2021.
Tags:
  1. blaisep
    blaisep Junior Member
    46
    22
    Santa Cruz California
    My rear window washer works fine.
    My front does nothing, not even a sound. It worked a few days ago.
    Does it have it's own fuse or something?
    I have not heard of these failing before.
    2008, 240k miles.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    Have you looked at the troubleshooting procedure in the factory service manual? I might expect it to be something along the lines of "test for power and ground at the washer pump connector while activating the switch. If both are good then replace the pump. If not good, test the wiring and switch."
    FYI the wiring diagram shows the front and rear washers using the same fuse.
    49,446
    for such a simple thing, it is a fairly complicated system. you have the two switches on the stalk, the clock spring, relays, fuse wiring, pump, tubing and nozzles.
    potential for troubles all over the place
  4. PriusCamper
    PriusCamper Senior Member
    11,093
    4,515
    Pacific Northwest, USA
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Mines doing the same thing. Sometimes both work sometimes both do not
    Like it’s a B+ or grounding issue. I checked the fuse and it’s ok.
    I have already replaced both pump motors years ago. The little pump motors are plugged into the bottom of the bottle. When I replaced them both last time I got the front and rear reversed but too lazy to go back in and swap them.
    Next time I will test the configuration before buttoning it back up.
    looks like I’m going back in soon. Hoping it’s not a clock spring issue.
    It’s always something with a 14 year old car but I bought it new.
  6. JC91006
    16,482
    8,397
    I have an OEM used windshield wiper motor. If you want to try it, I'll sell it for $25
    Raytheeagle likes this.
  7. blaisep
    46
    22
    I may take you up on that. At the moment I am driving cross country and don't have access to work space or tools.
    If you live near interstate 80, I can stop and visit.
  8. JC91006
    16,482
    8,397
    I live in SoCal, near Pasadena
  9. PriusPaddler
    PriusPaddler Member
    119
    Twin Cities, MN
    Before you buy a new part - park somewhere dry and try it. Then check and see if the water is coming out and going on the ground. Possibly the tubing disconnected? Maybe not if you don't hear the motor trying... but I'd check anyway.
    blaisep likes this.
  10. mr_guy_mann
    3,461
    1,505
    NJ-USA
    Ummm, what does the clockspring have to do with the windshield washers? Don't think that there are any wiper controls on the steering wheel.
    The wiring diagram shows a common 20A fuse for both washers, and each is separately grounded by the combination (wiper) switch. If the wiper switch ground was bad I might expect it to affect rear wiper and front (intermittent) wiper operation as well.
    blaisep likes this.
  11. blaisep
    46
    22
    Oh, that sounds like a good tip. Do you happen to have a link to an image?
    I can search for "Prius combination (wiper) switch" and see what I can find.
  12. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Yeah I meant the stalk not the clock spring.
    thinking it’s in the steering wheel it’s the clock spring nope…
