Front Windshield Washer Fluid Not Coming Out
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, Jul 13, 2017.
  1. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Hello. I just noticed yesterday that no windshield washer fluid was coming out onto my windshield. I could not hear any motor going when I pulled on the wiper lever. I don't usually pay attention to the noise when I clean my windshield. So I am not sure if any noise can be heard when I pull on the wiper lever. The windshield wipers do come on like usual but without any washer fluid. The rear windshield washer fluid comes out when I turn the lever for the rear. I also checked the washer fluid level and it is close to being full. I am not sure if it is a bad fuse or bad washer pump? Any help would be appreciated. Thank you.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Might want to try this work up first and then go from there:
    kkj2go likes this.
  3. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    Has the biosphere blocked the sprayer nozzle?
    Usually what happens here if the car is parked outside for some time between spray uses and then doesn't spray.
    Poking with a pin does the trick mostly.
    David S.
    kkj2go likes this.
