Frozen Belt Tensioner
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aiyo, Nov 28, 2016.
  1. Aiyo
    Aiyo Junior Member
    North Carolina
    Hey, folks! The belt tensioner on my 2005 Prius is frozen! I mean, I cannot get that sucker to move for the life of me! I have completely unscrewed the tensioner bolt, but the tensioner hasn't even moved. I've tried unscrewing the pulley bolt, but that bolt is stuck. I cannot break it loose. I've tried applying penetrating oil and allowed the oil to sit overnight. I still can't get it loose and I'm afraid of rounding the edges. Could I somehow just force the tensioner to go down so I could put the belt on or is there any tricks to getting the serpentine belt on without messing with the tensioner?
    If you're curious, I've gotten the belt off the tensioner by removing the water pump pulley, because I had to replace the water pump. But now I can't put the belt on.
  2. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    You have to loosen the tensioner pulley bolt to get tensioner moving. You can try to put some penetrating oil into back of the bolt.
    Just get a good 6-point socket onto that bolt and long ratchet or small breaker bar to it. It will either open it or snap the bolt. If the bolt snaps in two you can still disassemble it. But probably the bolt will just open.
    blauweaaf and Aiyo like this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    I remember that bolt too. Use a 6 point like Valde says and not a pos socket a name brand like Craftsman not harbor freight and put a pipe over the end of a breaker bar so its like 3 feet long. I use 3/4 emt piping from Lowes in the electrical section. Like $4. Sold in 10 foot sections you can cut it down to any length right there at the store with a hack saw. When the breaker bar is 3 feet long then your talking. Just put some pressure on it and wait...then some more...and then some more...go slow and eventually the bolt will walk off. Don't go full power right away or you'll snap the bolt off. Patience.
    I keep a 3 footer in the trunk when I have to change a tire on the road. The damn tire stores put them on with impact wenches. Try getting them off with a regular socket wrench.
    Aiyo likes this.
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    That bolt is a PITA. I would just buy a new tensioner and be done with it. I mangled that bolt on mine with I did my water pump R&R. Fortunately I took someone's adise on PC, most likely Ed's or Patrick's and bought a new tensioner at the time, in the event I knackered that bolt. And as advertised I destroyed the bolt. I did everything you've tried in the end I think I had to cut/grind off that bolt head to remove the tensioner assemble to replace it.
  5. Mendel Leisk
    40,574
    Coming from Honda, I was dismayed at the amount of rust on Prius bolts. I think their spec's are lax.
    I'm getting cagy: anything I take off I'll lube before reinstall. And I'll go out of my way, to remove/lube/reinstall some. Or just coat them without removal, hopefully reduce moisture incursion, internal rust.
