Frustrated installing amp and subwoofer
Discussion in 'Gen 2 Prius Audio and Electronics' started by Kutanks, May 16, 2011.
  1. Kutanks
    Kutanks Member
    118
    MA
    Last weekend I picked up an Alpine MRP-500 and a 10" type-r to go in my Prius. I got the amp wired up to the power, ground, and remote leads without a hitch. I then proceded to run speaker cable from the right and left doors. After hooking up the sub and reconnecting the battery the system doesn't work. I believe the problem is the wiring connections. I used the red (+) and white (-) wire for the right channel and black (+) and yellow (-) for the left. Did I use the right wires?
  2. svitale75
    svitale75 Prius Addict
    39
    Yes, I think you are using the proper wires.
    If I understand this right, you are feeding your amp using your radio rear speakers output as an input as oppose of using a preamp out.
    If this is correct what is exactly not working?
    Does the amp power up and has no audio?
    Are you using the stock radio or after market?
    FYI
    Up to 2009 Prius speaker pinout:
    Left front speaker (+) - Pink
    Left front speaker (-) - Violet
    Right front speaker (+) - Light green
    Right front speaker (-) - Blue
    Left rear speaker (+) - Black
    Left rear speaker (-) - Yellow
    Right rear speaker (+) - Red
    Right rear speaker (-) - White
  3. Kutanks
    Kutanks Member
    118
    MA
    yes the amp powers up and doesn't output anything through the subwoofer. I tried using an rca jack to headphone cable and plugging in my ipod to the rca input on the amp. This didn't work either. Im gonna go out and check the connection from the amp to the sub, maybe the leads inside the box are loose.
  4. Kutanks
    Kutanks Member
    118
    MA
    yeah im using the stock radio with the 6CD changer
  5. Kutanks
    Kutanks Member
    118
    MA
    I checked the box...seemed fine to me, one more thing im gonna do is go out and plug the speaker wire from the sub directly into the amp (as opposed to going through the box first). Next is to check the input signals in the door panels, really don't want to take them off again tonight so that might have to wait until tomorrow. It seems to me through that since the amp is powered up it should drive the sub when i use my ipod through the rca port.
  6. Kutanks
    Kutanks Member
    118
    MA
    ugh..still wont work. guess ill just disconnect everything and have the guys at best buy install it. Oh well
  7. Kutanks
    Kutanks Member
    118
    MA
    Before I do that though is there any chance that the amp isn't getting enough power? im running 4ga wire and 4ga ground but i din't upgrade my negative battery cable to 4ga. not sure if that makes a difference or not. Im gonna go cut the power cable down to size now that I have gotten the amp to come on. Then tomorrow im gonna go in and rewire the speakers to ensure a good connection. The next step is drilling holes in the cargo area to run the wires
  8. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Maybe the amp was bad out of the box. Have BB check it first.
    I recently installed an 8 inch power subwoofer in my truck. As a quick sound test, I connected the amp +/- leads to the head unit +/- connections since I was all ready deep into the dash getting to the radio's subwoofer pre-outs. I had weak sound, muddy bass, and blew fuses when even remotely pushed (radio @ 22 out of 40 volume scale). Later ran + to the battery and - to a chassis ground: MUCH stronger amp performance.
    Good luck.
  9. svitale75
    39
    I think you have plenty of current, one last thing your could try is to ignore the remote 12VDC for a second and put a jumper between +12VDC and remote. If the amp power up, try the RCA to ipod again.
    The amp might have a fuse close by the terminal block, check that fuse.
    As fotomoto said, you maybe dealing with a defective unit all along and the instal has nothing to do it with the amp condition.
    I would bring the unit back either for a refund or exchange.
    Hope this help and good luck! :rockon:
  10. svitale75
    39
    In general...Yes I won't run anything less than 4AWG for both positive and negative power wires. THIS is my latest install.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Are you just using the high level inputs on the amp? No high to low converter? Have you made sure your amp settings are correct and the gains are turned up high enough? Sometimes high level inputs are low in signal strength and need to be boosted a bit.
  12. Kutanks
    Kutanks Member
    118
    MA
    Im gonna take it back to best buy today and try another. will report back afterwards
  13. svitale75
    39
    on F8L point, if your amp cannot handle the high level input, you might need to get a converter box like THIS one.
    Some old amps have a similar device built in but I am not sure about your amp.
  14. svitale75
    39
    OK, I found out that your amp has a speaker level input on a dedicate harness.
    Is that what you are using?
    Alpine MRP M500 specs
  15. car2lvr
    car2lvr Junior Member
    34
    North Burbs, IL
    I had the same issue's on 09 prius, jbl audio, no navigation. I connected everything right and no sound coming out on the subwoofer. I even use the the high or low input on the amp and still no sound. Solution: I use a line out converter and everything works.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Aye. I never use the high level inputs on the amplifier. A converter is the way to go unless you are using a more expensive OEM interface module.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. We usually use the SVEN4 or SVEN2 at the shop.
  18. Kutanks
    Kutanks Member
    118
    MA
    Figured it out guys, my ground wasn't good. Reattached it to the bolt next to the battery. Thanks for the help I still have some fine tuning to do to the system but it sounds really good.
  19. Kutanks
    Kutanks Member
    118
    MA
