Fuel brands revisited
Discussion in 'Gen 2 Prius Fuel Economy' started by Syclone, Sep 4, 2006.
  1. Syclone
    Syclone Member
    540
    I've got about 4500 miles on my Prius (service soon). I've filled up about 11 - 12 times. Average MPG is about 43 -44. Probably 8 of those refills have been at a local BJ's. Based on what I've been hearing from the rest of the local Prius group, this is not anywhere near the mileage that they are getting. Local mileage for short trips is around 40
    The last time there was a thread on gas brands and fuel mileage was in 2004.
    Is there any consensus about which brands offer the best mileage. I have a feeling that this may have to do with the relative amount of Ethanol mixed with the gasoline. I think that all of the local gas stations claim to be using 10 percent Ethanol.
    Also, does anybody know about any actual testing?
  2. HokieHybrid
    HokieHybrid New Member
    200
    I previously bought primarily Shell gas b/c I had a rebate card that gave me Shell Gas. I got a new rebate card....so I get 5% of any gas...not just Shell. Soon afterwards I started complaining about a drop in my fuel economy. I have found Shell gas to give me 2-3 mpg more than my Sheetz tanks. My father swears Texaco is even better than Shell, but there isn't one I pass frequently so I cannot confirm it in the Prius.
    I stopped buying Mobil when they merged with Exxon. At that point I was driving my dad's 1996 Ford Ranger....and if you put Exxon in it would rattle like crazy. Any other gas, no rattle.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I usually always get gas at BJ's and usually get 48-50 mpg
  4. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    I regularly get my gas at either Chevron or Arco or occasionally even Shell or Mobil, depending on which one I'm nearest to when I decide to get gas. I've never gotten a full tank (ie: 400 miles or more) averaging less than 47.8mpg which also happens to be my lifetime average, go figure. I'm pretty sure the gas in CA doesn't have the ethanol blend like I know a lot of the midwestern states have been getting, so we don't have that to worry about (yet?).
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Here in AZ, I've noticed better mileage off of QT branded gas (claimed top tier) than I do off of some of the other cut-rate brands. I'm not loyal to any one brand, but more to price.
  6. 200Volts
    200Volts Member
    429
    43
    Northern CA
    No difference. I drive 1k per week and have tried many brands and grades with no difference noticed.
  7. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    During my first year of ownership I used BP and Exxon almost exclusively. Those were the only "good" gas stations around. I didn't feel comfortable getting gas from a no-name gas station. Now that I'm in a more urban environment, I use whatever is close by. Wawa, Sheetz, Chevron. But not Citgo. I noticed about a 3-5mpg hit when I used Citgo gas for about 4 consecutive tanks.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i use either Arco or Costco both with 10% ethanol mix (cant buy anything around here without it) only because they are the cheapest.
    safeway started this purchase $50 and get a one time fillup with 10 cents off (that usually makes their gas a few cents cheaper than Arco) my so my SO uses them.
    there is no real difference in unleaded regular anyway. so if you are spending a penny more for brand name gas, you are wasting your money. the biggest thing to look at is how the station you go to is maintained. poorly maintained stations also probably have gas storage tanks that are not maintained properly either. that will cause more issues than any brand will
  9. aaf709
    3,862
    2022 Prius Prime
    I use Arco, largely due to price and convenience (most of the stations closest to our house are Arco stations). In CA, at least, they're owned by BP.
  10. CrazyRussian
    CrazyRussian Junior Member
    42
    After driving for 8K in Phoenix, I've observed the following, driving the same roads in a similar weather:
    Shamrock - 57-61MPG
    QT - 55-58MPG
    Costco - 49-53MPG
  11. Syclone
    Syclone Member
    540
    Thanks for all the info - people. As soon as I get back home, I'm going to check out other gas brands besides BJ's. I'll post what ever I find out, if anything. I'm away from NY, down in Knoxville right, but should be returning in about a week. Then the next task is to figure out the cost/mile of other brands, since BJ's gas is usually about 8 to 10 cents cheaper per gallon.
    By the way, I've seen quite a few Prius's in the Knoxville area - about 5 or 6 in the 4 days I've been here.
  12. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Gas is gas. The ethenol content causes more of a difference then the brands do. Gas comes from the same pipelines and while there are minor additives they don't amount to much.
    A poorly run local station could have impurties in the gas but thats quite rare. I have noticed no difference in mpg regular vs premium or brand to brand.
  13. zoomx7
    zoomx7 New Member
    22
    I know that several car manufacturers (I think, Toyota, BMW, Honda & GM?) got together with some fuel companies and asked them to adhere to some guidelines regarding detergent additives for their gasolines.
    I believe Shell, amongst a few others that I can't recall, agreed to this standard.
    These companies are suppose to have the "cleanest" gasolines.
    If anyone knows the other companies beside Shell, please post.
    Thanks
    mfc
  14. curtissac
    curtissac New Member
    187
    <div class='quotetop'>QUOTE(MyTFineCar @ Sep 8 2006, 10:22 PM) [snapback]316810[/snapback]</div>
    According to http://www.toptiergas.com they are
    QuikTrip
    Chevron
    Conoco
    Phillips
    76
    Shell
    Entec Stations
    MFA Oil Company
    Kwik Trip/Kwik Star
    The Somerset Refinery, Inc.
    Chevron-Canada
    Aloha Petroleum
    Tri-Par Oil Company
    Shell-Canada
    Chevron, Shell, and 76 (part of Conoco Phillips) are the only top tier sellers around here. I stick to these. Prior to top tier I stuck pretty much to Chevron because I felt Techron was the best of additives - I am biased here as a formerChevron employee (in the interest of full disclosure). But ask people that actually tear down engines and most will tell you that they can tell who uses cheap gas - most mechanics I know don't use grocery store gas.
    On an almost exclusive diet of Chevron our Dodge Spirit went 187,000 running fine (transaxle died so we shot the car). My 1995 Explorer was still passing smog tests and hadn't lost 1 MPG of efficiency at 203,000 (the air conditioner and front differential died very close together - car euthanized.) My Hyundai was running fine but suffered a premature death at 57,000 miles when I committed vehicular sodomy upon a Ford Ranger on interstate 80. That incident moved my Prius purchase schedule up.
    I stick to fuel with known quality additives and shop price among them. Around here Chevron, Shell and 76 can differ by as much as .05 per gallon.
  15. bernzx
    bernzx New Member
    56
    I have heard that adding 10% ethanol to gasoline will reduce your mileage by 10% because ethanol has less btu's per gallon.(Can anybody confirm this?)
    So say you are getting 50mpg on gas at $3.00/gal and you switch to 10% ethanol at $2.90/gal and now you are getting 45mpg(10% less) and you are traveling 400miles. How much are you saving?
    $3.00/gal x 400mi/50mpg = $24.00 (cost of trip on gas)
    $2.90/gal x 400mi/45mpg = $25.77 (cost of trip on 10% ethanol blend)
    $2.85/gal x 400mi/45mpg = $25.33
    $2.80/gal x 400mi/45mpg = $24.88
    $2.75/gal x 400mi/45mpg = $24.44
    $2.70/gal x 400mi/45mpg = $24.00
    In this example, the 10% ethanol blend has to be 30 cents(10%) cheaper than gas to equal the same cost per mile.
  16. vkykam
    vkykam New Member
    27
    If 10% ethanol blend gets 10% less gas mileage by the logic that you have heard, that means essentially ethanol would have had no energy content at all, which is not true.
    About 2-3% I believe is an accurate number. The 10% number came from E85 versus gasoline.
    The plus about ethanol is that it's from renewable resources (although it takes a lot of electricy to produce, and power plants could burn NG or coal), but it does burn cleaner.
    <div class='quotetop'>QUOTE(bernzx @ Sep 9 2006, 02:38 AM) [snapback]316872[/snapback]</div>
  17. TomSwift
    TomSwift Member
    37
    Louisville, KY
    2014 Nissan LEAF
    The energy content of MTBE is about 93,500 Btu per gallon and the energy content of ethanol is 76,000 Btu per gallon, while that of conventional motor gasoline is about 114,000 Btu per gallon.
    I believe that a “real world†study to examine the impact of reformulated gasoline on fuel economy showed a 2 to 3% decrease in mpg that could be attributed to using reformulated fuel. That study is: “On-road study of the effects of reformulated gasoline on motor vehicle fuel economy in Southeastern Wisconsin, Wisconsin Department of Natural Resourcesâ€. The EPA also suggests that RFG will reduce fuel economy by about the same amount. That URL is:
    http://www.epa.gov/orcdizux/rfgecon.htm
    For many of us, the discussion is of academic interest only. We live in parts of the country where RFG is required and it is the only game in town. The question is of greater interest, perhaps, to those folks who can use E85 versus gasoline. How cheap would E85 have to be to compensate for the drop in fuel economy?
  18. dragonfire_777
    dragonfire_777 New Member
    22
    Don't think because you drive into a gas station branded or otherwise your getting their brand. Most gasoline is delivered to stations by wholesalers and you have no way of knowing where their stock came from.
    Case in point. I get some of my gas from a Shell station near me. I was driving by one day and there was a Union gas tanker dropping it's load into the Shell tanks.
    That being said my guess is that most stations deal with the same wholesale companies on a regular basis so the relative quality of the product sold by a particular station is hopefully consistent.
  19. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(vkykam @ Sep 9 2006, 10:26 AM) [snapback]316944[/snapback]</div>
    No, I think a 10% reduction in mileage for ethanol in a 10% ethanol blend means you would get a 1% reduction overall (10% of 10%). This might be flawed...I'm not a mathmatician.
  20. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Coincidentally, I have been experimenting and testing different gas from different vendors.
    In this experiment, I got my first tank at 76 and averaged 48 MPG, the second at Chevron and averaged 51, the third at 76 again and averaged 47.6, this tank is from Chevron and so far I'm at 50.6. Weather and driving have been about the same through all tanks. It seems I get better MPG from the Chevron gas.
    Prices are still up around $2.86 here in blue Oregon where we require professionals to fill our tanks, but the prices are about the same in Washington, where you pump your own (Ah, don't you just love the smell of gasoline on your hands!).
    The problem, as I have said before, is that we buy gallons, not energy. Temperature, alcohol content, and who knows what else affects the energy content of a gallon volume of "gas". Still, my Silver Cloud is more fuel efficient than any other car I have owned, so I'm happy. For now.
