fuel consumption
Discussion in 'Gen 3 Prius Fuel Economy' started by Ismail Asha, Sep 15, 2017.
  1. Ismail Asha
    Ismail Asha New Member
    Amman
    Hello,
    please if there anyone can help me, I JUST bought A prius 3 Persona series 2015 ,and and CONS for 400 Miles is 37 not around the 40 th , what i have to check
    all battery cells in same range of voltage
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    What were you previously driving and did you hand calculate the fuel economy on that vehicle?
    52,371
    how many miles/km on her? what tyres and pressures? what does the 12v measure, stone cold? are the air and cabin filters clean? is the oil level too high? is the battery cooling intake grille clean and clear?
  4. Mendel Leisk
    41,882
    Just a few things I can think of that can impact miles per gallon:
    1. Mostly short trips, when the engine doesn't warm up.
    2. Lots of air conditioning use.
    3. High speeds. Fuel economy drops in a very linear manner as you get into higher freeway speeds.
    4. Driving style: overly aggressive acceleration, not coasting up to traffic slow downs, and so on.
    5. Tires: under inflated, and/or high rolling resistance.
    6. Failing 12 volt battery.
    How many miles on it?
  5. Ismail Asha
    Amman
    Yes i had calculated the fuel economy ,it takes full tank in 410 miles
  6. bisco
    52,371
    perfect.
  7. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    From the OP's location of Amman, Jordan, the weather is in the low 90's during summer days, and being the capital city, perhaps there's lots of stop and go traffic? I would guess that even with a well maintained Prius, if it is used in constant A/C operation and traffic congestion, mileage isnt going to get to EPA suggested of 50mpg, or 500 miles for a tank.
  8. Prodigyplace
    12,667
    11,828
    Central Virginia
    Jordan would use the Imperial gallon not the US gallon used by EPA..
    Their EPA equivalent would be higher too because their gallon is larger.
  9. Ismail Asha
    Amman
    yes i live in Amman , and it is a mountains area and a lot of traffic, before few days the temperature was 100 F, 43 C,- here we use KM/L but i have using MPG since my Prius , but i worried because of some of my friends has the same Prius and there CONS, above 40
    I will change the plug sparks, motor oil, injections and make sure of hybrid cooling system "" i have cleaned before a month " when I bought the Prius
    and i will get get back to you soon, to share the experience
  10. Prodigyplace
    12,667
    11,828
    Central Virginia
    Spark plugs should not need to be changed. Check your tire pressures. Higher pressures tend to give better fuel economy but a little harsher ride.
    You should be using a synthetic 0w20 oil. Many of us prefer either Toyota's oil or the Mobil 1 brand, whichever is less expensive.
    It is always a good idea th check the hybrid battery cooling fan & filter. If it gets clogged the battery can get too hot, affecting fuel economy.
    Ismail Asha likes this.
  11. bisco
    52,371
    how many miles on her? a 2015 shouldn't need much of anything.
  12. Mendel Leisk
    41,882
    Maybe yes, maybe no. Probably best to stay with whatever the Owner's Manual, and/or authorized Toyota dealerships recommend in your country. Sounds pretty hot there.
  13. Prodigyplace
    12,667
    11,828
    Central Virginia
    True.
    My son's US 2015 Prius v uses synthetic 0w20
  14. Ismail Asha
    Amman
    I just want thank you guys, the CONS. avg is getting high to be 45 , i like share my experience with you
    i have reduce the tires pressure and it work perfect
  15. MelonPrius
    839
    516
    Nevada
    That's a better number. The fuelly average of real life drivers are averaging 44 mpg for the 2015 Prius.
    However, reducing the tire pressure will rarely increase mpg, but will usually hurt it. Unless you meant by "works perfect" as having a softer ride?
  16. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Check your battery's cooling system. If the battery gets too hot, the HSD controller will stop using the battery.
    There could be hair and dust plugging the air filter to the battery fan.
  17. Ismail Asha
    Amman
    Usually soft driver, but when I go faster I have return the tires to the recommend pressure
  18. bisco
    52,371
    perfect!(y)
  19. Ismail Asha
    Amman
    What do you suggest ,how many miles should i consumed this oil
    5000 or 7000 or 10000
  20. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Driving in the mountains in my opinion is severe duty. You may want to try a shorter interval. But you're running a good synthetic oil which should take the abuse so it may not matter.
    Pixel XL ?
