Fuel cover stuck or latch not working? Help
Discussion in 'Gen 2 Prius Main Forum' started by jlr1218, Aug 17, 2006.
  1. jlr1218
    jlr1218 New Member
    How do I pop the cover so I can fill the gas tank? It's stuck. Or the latch won't open it? Only one bar left on the gas gauge. Brand new car - less than 1000 miles - only filled the tank once thus far.
  2. aaf709
    3,862
    2022 Prius Prime
    When you pull the lever, does it move at all? You might be able to get a tool to retract the pin, but I'd go to a dealer.
  3. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    <div class='quotetop'>QUOTE(JLR1218 @ Aug 16 2006, 11:13 PM) [snapback]304488[/snapback]</div>
    Assuming by "cover" you mean door, that's a problem those of us in the midwest see after awhile. It's caused by the spring going dry from exposure to the elements, sand, and salt. Usually, it takes a few years. But a brand new one could have simply could have come without any/enough lubrication.
    Just have someone pull the lever as you push on the door.
    Then spray it with a few shots of WD-40.
    kilomonk likes this.
  4. bpassman
    bpassman Junior Member
    Lexington, MA
    2001 Prius
    My spring, bent metal on 2001 Prius.
    I stick a small rubber ball under the lever after I pull up on the lever, so it stays pulled up, while I go out and open the gas door.
  5. kilomonk
    kilomonk Junior Member
    Central Florida
    Thanks, John. Still useful info for my 2006, 12 years later. Saved me from crawling under the car to tighten the cable.
