Fuel Economy dropped after spark plugs replaced
Discussion in 'Gen 2 Prius Fuel Economy' started by 1069FL, Feb 27, 2017.
  1. 1069FL
    1069FL Junior Member
    Newport News, VA
    Hello - In Jan. 2016, at 110,116 miles, I had the spark plugs replaced in my 2005 Prius at the local Toyota dealership. Right after, my mpg dropped from around 52 average to 47 average. Nothing else has changed. This average has been consistent for over a year now. I replaced the 12V battery in Jan. 2017 & I was hoping that would help but it didn't. I always keep the tires properly inflated. When I
    asked the dealership about this, I got stonewalled. What could they have done or failed to do to cause
    a drop in mpg? The receipt says the new plugs are Iridium. On the same day, they also changed
    the oil & filter, & replaced the hybrid transaxle fluid. I get all of my maintenance done at the dealer-
    ship.
    51,685
    how are you observing mpg's? do you keep a record of fill ups and dates? weather plays a major factor.
  3. 1069FL
    Newport News, VA
    I am only relying on the computer display of averaged mpg, which I have done for 12 years.
    The 47 mpg average has been consistent for over 13 months now, regardless of weather.
    I have lived in the same city in southeastern Virginia since I've had the car, where winters
    are relatively mild. I guess my concern is that the hybrid battery is getting weak, because
    it seems the engine runs more than it used to, resulting in lower mpg. I just can't figure out
    why it started right after the new spark plugs went in.
  4. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
  5. Samprocat
    491
    297
    Lincoln, NE
    Whatever people are saying that if you go with factory spark plugs you have already preset gap ....that is never right...i have found a lot of factory spark plugs out of specifications
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Yeah, if you drop the plug on its head and the gap goes out of whack. I've never had to gap a plug that was purchased specifically for a car.
  7. Mendel Leisk
    41,125
    Does it say the specific plug? One of these (from Owner's Manual):
    As far as gap, some of the high end plugs caution against adjusting gap. If the gap is close to spot-on, I would leave it alone; they are set at factory, and barring being dropped on concrete or something, should be ok.
    Do you set the pressures to spec, or higher? If the latter: dealerships are known to drop pressures back down to spec.
    What does the invoice say for the fluid? Should be:
  8. Former Member 68813
    3,524
    983
    US
    i beg to differ. a lot of things changed. it could be thicker oil/ATF they used. it could be massive "idling" they did that affected your MPG average.
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Given all maintenance was dealer performed and you did not mention any prior issues with them, I would suspect that they made a tire pressure change that increased rolling resistance.
    Could plugs, engine oil and the incorrect "ATF" be involved, sure. But since they are familiar with your car and most are good about getting the correct PARTS on customer's cars, TP seems the most likely.
    Also, no OEM suggests altering the gap on "Double Platinum" or Iridium plugs, because the risk of damage to the tips in doing so is VERY high.
  10. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    I'm having a very similar issue. No one in any of these threads has answered as to why people who just change spark plugs are getting a dramatic drop in mpg. I changed my spark plugs from Denso Iridium to NGK Laser Iridium and instantly lost about 10mpg. They were gapped properly I did check. I also know my tires are above 45 psi, I have a new yellow top battery, traction battery is a Dorman which was just put in, no check engine lights. So before changing the spark plugs I noticed over 52 mpg at 60 mph. Now it is about 42 mpg. My average has dropped the 10 mpg also. I did that for multiple tanks with no increase in fuel economy. I do feel like it has a miss or something when it is using the ICE but not when electric. So I replaced all 4 coil packs still no change. I drove like that for 3 tanks or so with no change. So I tried to put the old plugs back in. I've had these back in for about 2 tanks now with no change.
  11. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    How far away are you from @ericbecky? Maybe he can help you at his shop? Did you change out your PCV valve? Could the throttle body be dirty? MAF sensor dirty?
  12. Mendel Leisk
    41,125
    Assuming it's related to the spark plug change, and truely grasping at straws:
    1. Did you put dielectric grease on the coil connectors plugs, or between the coils and plugs? Maybe messing up the connections??
    2. Did you use a toque wrench? Dry thread torque is 15 ft/lb, and in the absence of any guidance I went with 13 ft/lb when the threads had a super light application of anti-seize. Basically what I did was put on a very thin coat, then wipe it off with a cloth, relying on a slight amount lingering in the threads.
    I did say: grasping at straws.
    Can't be the new plugs, since problem persists when swapping back to the old plugs. (n)(n)(n)
  13. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Hi Virginia!
    First of all, 52 MPG is outstanding is 47 is very good.
    On the Fuelly site, the average for 2005 Prius is 43.6 MPG.
    Your 52 and 47 are via display, not via real fuel consumption so 43.6 may be closer for you (display reads high).
    Use of the display MPG is part of the problem...as that data is not as good....
    I changed my own plugs, did not see a MPG change. I don't think I checked the gaps other than quick look.
  14. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    I did not touch my PCV valve. I cleaned the throttle body and MAF sensor with MAF sensor cleaner. This is my second 2nd gen Prius. My other one had 360,000 and everything was original and I averaged 52-58 mpg. My sister now owns that one with everything still original at 400,000. I did all the same things to that one and didn't lose any mpg. May have gained a mpg or two.
    Owner of "Little Green" and SFO like this.
  15. Mendel Leisk
    41,125
    Maybe something happened coincidentally, leading you to suspect the plugs? Weird as heck though.
  16. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    I did not put dielectric grease on. I did not use a torque wrench but I know I would be in the ballpark for its torque spec. I can check just to make sure.
  17. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    Yeah I thought maybe I messed up a connection to the coil? But I have no check engine light.
  18. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    I am about 4 hours from Madison WI.
  19. oil_burner
    oil_burner Active Member
    249
    126
    when you clean the MAF it typically takes a tank for the ecu to relearn the trims
  20. Mjh3889
    Mjh3889 New Member
    17
    Wisconsin
    That might be true but it doesnt explain why Mpgs lowered in the first place. It has been about 400 miles since that was cleaned. It didn't do anything. It's just all very frustrating. My 03 Civic Hybrid was far better at easily achieving over 60mpg average. I had a tank with 850 miles on it at just over 68mpg average for the tank. Without my auto engine stop feature ever working and my IMA light on due to a hybrid battery that was under 70%. If you are a hypermiler and don't do all city driving I suggest the Civic or Insight hybrids with manual transmissions. I never had to try in the summer and achieved over 60 mpg.
