Fuel Economy
Discussion in 'Gen 2 Prius Fuel Economy' started by nhalber, Feb 23, 2005.
  1. nhalber
    nhalber Junior Member
    83
    Marblehead
    I live in the Boston area and drive about 900 miles a month. Mostly divided between 1-2 mile trips and 15 mile ones.
    I realize that this isn't an exact science, but can I get at least 30 mpg?
    Thanks
    PS: also any recommednations as to tires?
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) You aren't clear.... Do you have your Prius yet or just consdering?
    You drive much like my "pattern" and with ~7,500 miles on the odometer, I am averaging about 45 MPG overall. When I drive the Interstate cruising at ~70 MPH, I manage about 50 MPG. YES, I get better fuel economy "on the freeway" contrary to EPA ratings.
    If you only achieved 30 MPG :roll: , you may need to read up on how to drive a Prius. There are good suggestions on this and other Prius Forums on adjusting your driving habits to maximize your fuel economy.
    I still have the stock OEM tires and run them at 38 psi front, 36 psi rear. Some folks run at 44/42 and feel that nets better mileage. I bought a good tire gauge and a 12v small compressor to enable me to keep the tire pressures steady.
    Enjoy your PRIUS
  3. kidtwist
    kidtwist New Member
    183
    In cold weather you will get lower mileage but I don't think it would go THAT low. However note that some Prius-bashing journalist in Detroit in the dead of winter was able to get one down below 30 mpg. I suppose he was running it with the windows open, the heater going full blast, driving it pedal to the metal at all times, and probably dragging a ship's anchor.
    NOTE: I don't own a Prius yet, I'm basing this on the research I've done.
  4. nhalber
    83
    Marblehead
    Thanks for the info. No, I am almost at the buying stage.
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    What are you driving. Many of us drove low mpg cars before our Prii. I had a Ford Explorer and as I was waiting for my Prius I started to practice some of the techniques described here. Some are Prius only others are applicable for any car. I improved my m.p.g. by about 2 m.p.g. during that period. I have to say the best part of driving my Prius is the calm created by driving for milage. My commute times have not changed and the whole thing is easier. Chill drive green. :mrgreen:
  6. CitizenjaQ
    CitizenjaQ New Member
    61
    Nashua, NH
    I commute 5 miles each way to work, so my Prius is just barely warmed up by the time I shut it off. I live about an hour from Boston, and I might travel there one or two times a tank, and I've never averaged below 40mpg a tank since I got the car in early January. On the highway I get about 50mpg.
    I'm about 1,200 miles in. I'm very much looking forward to summer and the end of my break-in period, especially since I'm already getting twice the city mileage of my Mazda Protégé (a sipper itself).
  7. canuckican
    canuckican New Member
    75
    Windsor, Ontario, Canada
    Kidtwist (just FYI)-
    I am getting less than 30 mpg and don't drag an anchor, jack-rabbit, or drive with the windows open. I live in Canada. It is cold here. I have to run the heater. I have to run the defrosters (front and back). I have a short commute. Certain conditions just are not conducive to high mileage. People need to get used to it, DEAL with it, and shut the heck up about low mileage.
  8. pepper04
    pepper04 New Member
    boston, ma
    I live in Boston too, and my commutes are 3-10 miles usually, and since I have moved here and it has been cold I have been getting very low mileage 20-25mgp. All my driving is city, and I do use the heat because it's cold and I need to defrost my car but I don't think I'm excessive. It may not be worth your while, I've had my car looked at several times and have been told by the dealerships that my low mileage is a combination of cold and short commutes.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You do realize that this thread is over three years old. I suspect the OP has made his decision by now.
    Tom
  10. Theodore
    Theodore Junior Member
    37
    Greece - Athens
    Question!!!!
    Hi......
    My name is Theodore, I live in Athens - GREECE and I am an electronic engineer. I have just bought a Toyota Prius and I would like to ask:
    How can I improve the MPG using more the battery???? I would like to inform you, that I have software and hardware for ECU tuning....I have already tuned the ECU of my girlfriend's Citroen SAXO. I did a remapping in the Ignition Timing Advance MAP....and the results are great!
    How can I change - tune the electronic control box of the Prius so to use more the battery (not only 40 % of discharge....but deaper like 15 or 10%)????
    Where can I find infos about that????
    Thank you!!!!
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Re: Question!!!!
    You don't want to do that. The Prius only uses the battery as an electrical flywheel to store and reuse small amounts of energy, allowing for a smaller and more efficient gas engine. Testing has shown that a larger battery does little for increasing mileage, unless you are talking about a plug in conversion.
    Increasing the depth of the discharge is equivalent to using a bigger battery, with the additional disadvantage of reducing the service life of the battery. You will not make any significant gains in mileage, and will shorten the life of your battery.
    If you still want to do some modifications, I suggest you think about Hymotion or some other plug in conversion which involves adding another battery pack.
    Tom
  12. richard schumacher
    7,663
    1,038
    United States
    You can't. You will get better MPGs by using the battery *as little as possible*. There are many posts which discuss why that is.
    It is extremely unlikely that you can improve anything by "tuning" the software. Totoya has spent more than ten years working on it. If you try, you will almost certainly either:
    - have no effect, because you will be unable to access the software (that will be the fortunate case)
    or
    - you will damage something. For example the battery uses a restricted range because that greatly increases battery life. Discharging it to 10% every time would ruin the battery, possibly within a few months. And it will void the warranty.
  13. Theodore
    37
    Greece - Athens
    Dear Sir!
    Thank you for your reply.....
    Can you give me some informations about Hymotion or Is there information in google search machine about Hymotion??????
    Thanks a lot!
  14. qbee42
    18,058
    3,074
    Northern Michigan
    Google search right from the top of this page.
    Tom
  15. Theodore
    37
    Greece - Athens
    Dear Sir!
    I have just received an email from Hymotion. Until today, they do not send any Hymotion plug-in in Europe.....In the future they are plannig to send it....
    Can you propose me another link...or links in Europe for a corresponding modification?
    Thanks a lot!:)
  16. qbee42
    18,058
    3,074
    Northern Michigan
    Unfortunately no, but perhaps some of our international members can help.
    Tom
  17. Theodore
    37
    Greece - Athens
    Europe Prius Plug-In modification!
    Dear Sir!
    Where can I take an opinion of an international member for the Prius plug-in modification in Europe??????
    Thanks a lot!
  18. qbee42
    18,058
    3,074
    Northern Michigan
  19. Theodore
    37
    Greece - Athens
    Re: Europe Prius Plug-In modification!
    Tom Thank you very much!
  20. westy72658
    westy72658 Jim Coleman Toyota in Bethesda, Maryland
    110
    67
    Louisa, KY
    Re: Question!!!!
    You may want to start a new thread to get the info. you are requesting...this thread is old...good luck
