Fuel efficiency improved.
Discussion in 'Gen 2 Prius Main Forum' started by VDIndia, May 1, 2008.
  1. VDIndia
    VDIndia New Member
    All through winter our 05 Prius was giving poor mileage, so finally in spring I took the Prius to service. Explained my problem. I wanted to know if it was winter driving or something actually is wrong with the car. They did not find anything wrong. They dump a bottle in the gas tank to clear all cylinders. Mileage has gone up.
    Have you heard about this before? If so, how often we need to use this bottle to clear cylinders?
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Coincidence?? You didn't specify actual mileage numbers, but mileage in winter will definitely be poorer than spring mileage. Provide some before and after numbers so people here can help you out better.
  3. VDIndia
    VDIndia New Member
    A cold winter day it dropped to 26 mpg, usually was giving around 36-38 mpg. Now after the clearing the cylinders with the fluid it has improved to 46-49.
  4. dougrs
    dougrs Junior Member
    Delaware
    did the temperature increase over the same time period?
  5. VDIndia
    VDIndia New Member
    Yes, temp has increased to 50 -60 degrees.
  6. richard schumacher
    7,664
    1,043
    United States
    Low temperatures reduce fuel economy in several ways. Many of these you cannot affect, but one you *can* affect is the tire pressure. You should check tire pressures at least monthly, or whenever the average temp changes by more than about 20'F. Reduced tire pressure can account for much of the MPG reduction you experienced.
  7. Bob64
    1,540
    93
    Virginia
    Thats your fix.
  8. Scummer
    Scummer Eh?
    174
    29
    Munster, IN
    My winter driving was in the 42-44 range.
    Now that temps have gone up and the gas has changed to summer fuel, i'm over 50mpg.
  9. richard schumacher
    7,664
    1,043
    United States
    Agreed. Don't waste your money in the future on additives.
