Fuel filter
Discussion in 'Prius c Technical Discussion' started by priusmatty, Jun 23, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    I heard that the fuel filter is permanent, and submerged in the fuel tank to cool it. Fair enough, but isn't it a bad idea to not be able to change a filter? What happens if it gets clogged?
  2. Kenny94945
    Kenny94945 Active Member
    787
    401
    Sausalito
    2016 Prius v wagon
    I wouldn't worry so much about this filter.
    Modern gasoline and modern gas stations are "clean" with the rare occurrence of ingesting dirt/ crude from the filling station into your gas tank.
    I have cut open multiple fuel filters with 75K mileage on them and they have been "clean as a whistle".
    My tips to retain clean fuel...use top tier brands (do a search), keep vehicle fuel tank above 1/4 tank (well, not the typical Prius way of life), don't add fuel while the station is receiving fuel (or shortly thereafter) from a tanker.
    PS What sucks is AMG Benz owner's fuel filters.
    In tank, two of them, built into to fuel pump, about $400 each, plus labor.
    Some on the maintenance schedule every 60K miles.
    Again, I wouldn't worry so much about this Prius filter.
  3. Mendel Leisk
    38,873
    Oy vey, you've had the car one, two days, and you're researching fuel filter change? You're worse than me, lol.
    As far as I know the Prius c filter is in the tank, and as such best left alone if no problems point to it. That said, the Australian maintenance schedule does include filter change, and it's a bear.
  4. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Haha I am pretty bad, yes. At what mileage does Australian maintenance require it?
