Fuel/fluid treatment vs EGR breakdown and cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Aug 25, 2020.
Tags:
  1. berderder
    berderder Junior Member
    69
    Connecticut
    Hi all,
    My title might not make a lot of sense - I don’t know exactly how to describe it.
    So, my skill level and confidence aren’t so high yet (just started learning). I called around asking if anyone does EGR breakdown and cleaning on the Prius.
    There is only one “certified hybrid repair” shop in like a 100 miles radius. They said they offer a sort of treatment where I imagine they pour something into the fuel tank to move through and clean the system? Specifically they said this helps with the carbon deposits on the EGR components. They quoted me $275 (I don’t actually know what the full treatment entails).
    What do you think? I’d like to break down the components and clean them myself, but like I said, I’ve just barely gotten comfortable with the basics. Mine is a 2014 with about 123,000 miles on it. You can bet the EGR cleaning has never been done before, I’m the 2nd owner.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I think you should not "fix" it if it isn't broken.
    A LOT of vehicles go over 200K miles and never touch some of the things that are "popular" for the tinkerers to screw with.
    But no, "snake oil" isn't a fix for much of anything.
    And a little carbon residue isn't the end of the world either.
  3. Mendel Leisk
    42,373
    DIY is the way to go. Trying to get it done professionally will more'n likely be ineffective, frustrating AND expensive.
    Ed Beaty likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Your title is “junior member”. It makes total sense to me. Once you become a senior member, there’s no going back.
    berderder likes this.
  5. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    I don't think I've seen a post here on PriusChat where a fuel or oil additive approach was shown to be helpful for cleaning EGR components. Once you get your mitts on a clogged EGR cooler you'll see how unlikely that is.
    If you want to gain some confidence in DIY, maybe try starting with just the intake manifold. It'll give you wrench time and you'll get an idea how clogged the EGR path of the intake manifold is. While you're at it might as well get the PCV valve if it hasn't been replaced recently. Yes the cooler is a bigger job, but in the end it's just one nut at a time, with the occasional setback thrown in to keep things interesting. Good luck!
    berderder, Mendel Leisk and Ed Beaty like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I’ve been telling others to start with the egr pipe :eek:
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Where in Connecticut are you located :whistle:?
    @Bay Stater has done this work on the egr circuit before, and he might be local:).
    Good luck and keep us posted (y).
    Bay Stater, SFO and berderder like this.
  8. berderder
    69
    Connecticut
    Oh nice! I mean Massachusetts isn’t terribly far away. I’m in Southwest CT (Bridgeport).
    Mendel Leisk and Raytheeagle like this.
