fuel gauge/bars
Discussion in 'Gen 2 Prius Fuel Economy' started by MEATHEAD, Aug 30, 2008.
  1. MEATHEAD
    MEATHEAD New Member
    DIRTY JERSEY
    SO my 2007 prius indicated i got 49.4 mpg on higway I was doing between 60-70 all highway
    i have 375 miles on it and 1 bar left
    last time i filled i had 3 bars left my car took 7 gallons and i have 12 gallon tank
    anyone have similiar issues
    Is there a fix?
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Normal behavior, nothing to fix. Short answer: it's attributable to the flexible fuel bladder.
    This is one of the most commonly asked and answered questions on PriusChat. The Search function works very well. ;)
    Peter Larsen likes this.
  3. jimsoh
    jimsoh New Member
    30
    west central Ohio
    Just how does the flashing pip work, that is... what turns it on and why or how is it so unpredictable. Right now I'm hualing around 3-1/2 gals. of gas and wanting to empty my tank, in an attempt to learn more about this situation. (I'm at 65 miles after the last pip began flashing).
    I've got the scan guage, but assumed fooling with the fuel & miles remaining would be a crap-shoot.
    Any words of wisdom, from the more experienced Prius owners.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's not unpredictable. It works quite well. When you get the flashing pip, you need to get gas right now. The Prius gas gauge does a good job telling you when the tank is getting low. What you don't know is exactly how much fuel is in a full tank. It varies.
    Tom
  5. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    The flashing pip does exactly what it's programmed to do: it tells the driver to get gas.
    The true issue is to find out how well the driver works.
  6. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    It does depend on the baldder. Ive got between 380 and 475 miles when the blinking starts. It takes the same 8 to 9 gallons.
    I have found that I get the best milage when i got the Auto climate control off.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Did you have a bigger tank fitted? Everyone else says they have a 11.5 gallon tank according to the book.
    I see you have already been told about the bladder and how the gauge is very good at telling you when to get fuel, the handbook in your glove box also says, like just about every cars handbook, keep the level of fuel in the tank above 25% full. For this reason I always fill up at 2 bars on the gauge. You can often get more fuel in if you pause after the pump clicks off, wait about 30 seconds then fill again. This lets the air out. Shake the car from side to side can help too. Beware, this may cause harm to the vapour recovery system but it may not.
    Fill past first shut-off at your own risk.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Not sure why you resurrected this old thread. Book says 11.9 gallons, not 11.5, so 12 is a reasonable value.
  9. qbee42
    18,058
    3,074
    Northern Michigan
    A reasonable value for what? Gross capacity? In that case yes. Certainly not usable capacity in the North American model.
    Tom
  10. patsparks
    10,664
    567
    Neither am I Shawn, it came up in a search of unread posts, baffled. Should we let it die again?
  11. Celtic Blue
    2,224
    139
    Midwest
    Gross capacity, which is what the manual lists and what one would use for other vehicles as well. Yes, it is true that the NA Prius is inordinately handicapped with regard to its useful capacity.
  12. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    To the OP...
    Even though you only had one PIP yet I would say you could probably run it to about 500 miles on that tank before the ICE cut out due to lack of fuel (assuming the bladder was behaving at last fillup to a full tank).
    Assuming no bladder problems, think of it like this. Your fuel tank is much like an aquarium, imagine taking a typical aquarium and pouring a gallon of water into it. You'll notice it'll fill up what... maybe 1/2" of water across the bottom? Likely hardly enough that the pump can pick any of it up. So, let's say your 11.9 gallon rated capacity tank actually has an effective 10 usable gallons in it (again, asuming a full tank with no bladder problems). So, also assuming your MFD is accurately calculating your fuel mileage and your driving style is consistent throughout that tank, you should be able to multiply your MPG by the 10 gallons and estimate your usable range.
    50 MPG = 500 miles range (estimated).
    That's what I go by.
