Fuel gauge calibration in 2010 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by deltron3030, Jan 3, 2010.
  1. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    The Gen II directions don't seem to apply to the Gen III (no on/off ODO). does anyone know how to do this DIY?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I guess I would need a little more information to know for sure what you are asking. I didn't know the fuel gauge could be calibrated in the Gen2. :confused:
  3. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    I just returned from a long trip (~3000km return). I noticed that when my last fuel gauge pip starts flashing and the car beeps, there are still about 8-9 liters in the tank. It seems to go into flash mode too soon.
  4. tumbleweed
    4,067
    690
    Eastern Oregon
    I have let mine get down to the last pip blinking a few times and have had about 2 U.S. Gallons (7.6 liters) left. That's quite a bit but it seems consistent so I could note the mileage, or reset one of the trip odometers, when it blinks and predict pretty close how much further I could make it if necessary.
  5. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    OK, good to see mine is in the normal range. Thanks,
    Paul
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The calibration the OP is referencing is a float calibration function used to set the full mark on level ground.
  7. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I got the first beep and then drove until the autonomy showed less than 20km - I fueled up and only 37L went in. This means that when the first beep comes, you probably have still 9-10L fuel in the tank - a bit too much for my taste - I was used with 5L on my Polo when the autonomy was 0km and the indicator was clearly on empty and the fuel light was on...
  8. tumbleweed
    4,067
    690
    Eastern Oregon
    Thanks Spinnr now that you mention it I do remember it existed, never had occasion to use it though. Apparently the Gen3 has no such feature? at least I haven't seen it referenced anywhere.
  9. pakitt
    2,173
    1,313
    Colorado
    I found this on the manual - did not notice it when I first read it (I have to read the german version and it is tough for me, not being a native speaker...):
    "The minimum amount of fuel to add to make the low fuel level warning light go out is about 1.6 gal. [6.0 L, 1.3 Imp.gal.], when the vehicle is on a level surface. This value may vary when the vehicle is on a slope."
    but also:
    "Low fuel level warning light
    Remaining fuel (Approximately 1.6 gal. [6.0 L, 1.3 Imp.gal.] or less)"
    But this is not what I experienced - when the light starts blinking if I go fuel up, I see that I had still 9-10 liters of fuel in with autonomy not zero! Even when I tank with 0km autonomy I see that around 7L were still in the tank....
    I am confused - how do I know when the 6L reserve is starting to be used?
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    IMO it's still a "Guess Gauge". I haven't had the car long enough to develop a comfort level with any of its gauges. There's a fuel pump in the tank cooled by the gas. No point in running the tank to empty.
  11. PuckSR
    PuckSR Junior Member
    35
    So, did anyone ever figure out the procedure on this?
    My 2011 ran empty the other day but was showing half a tank of fuel according to the indicator.
    It sounds identical to the issue experienced on Gen II prius and it isn't even an odd automotive problem, just curious if this is something I need a dealer to do or something I can DIY.
  12. fuzzy1
    10,335
    ^^ I can't answer your primary question, but must ask one myself. Have you verified that the tank actually ran empty, and that the fuel starvation wasn't the result of some mechanical failure to get fuel from the tank to the engine?
  13. PuckSR
    35
    I verified it.
  14. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well you're all wrong. If you actually -fill- the tank (until you see fuel in the filler tube), you will find you put in about 10 litres more after the first nossle cutoff. ;) And you can go 200 km before the first pip disappears.
    It "ain't" a laboratory instrument!!
  15. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    With the exception of post #11, one would think Toyota is error-ing on the side of caution with full capacity calibration and leftovers for "indicated" empty. Can you imaging the uproar and lawsuits if as soon as the tank showed empty...you ran out of gas?
    Post #11 "sounds" more likely a stuck float or wiring issue.
  16. PuckSR
    35
    This is a long-standing "feature" on cars. Fuel tanks are not perfect geometric shapes. They also have a tendency to be in motion.
    Any fuel indicator can't be "perfect" because the car might stop running before the indicator reported an empty tank. It also will show "full" before the tank is totally full because the level indicator only goes to the top of the main geometric object. It doesn't can't possibly include all cavities.
    My problem is that the sensor(a level transducer) reports incorrectly. If you are curious about how transducers work: OMEGA Engineering : Process Measurement and Control Products
    Gen II owners report this issue frequently(one of co-workers even had it). The solution was a re-calibration. It looks like my car is experiencing a very similar problem. I had another "out of gas" incident a few months ago. My car reported 2 "pip", but ran out of gas. I assumed it might have been blinking or I hadn't remembered correctly(the fuel level is blocked out until you clear the code, which I did after filling the tank). This variance has me believing that I either having a failing level meter or I am in need of a re-calibration.
    I probably should have started a new thread. The idea that your car might not report a perfectly accurate fuel level in all usage scenarios is a well-known feature of operating a motor vehicle. The need to change your calibration factor is not a normal issue.
  17. frodoz737
    4,535
    2,438
    33
    PuckSR...provided below is what you need. Note that on Page 3031 it gives you the values to check the sending unit. Per the manual, it the values are not within the specified range, replace the sending unit. Appears there is no-vehicle calibration. Though it could be something else, this is the most probable cause and good place to start.
  18. PuckSR
    35
    Thanks. Just noticed I never said that
    XT1049 ?
