Fuel Gauge Issue
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Gabriel Rockman, May 9, 2016.
  1. Gabriel Rockman
    Gabriel Rockman Junior Member
    23
    Montgomery Village, MD
    2014 Prius c
    This morning I started my drive to work with 2 bars on the fuel gauge. A little bit into the drive it dropped from 2 bars to 1 bar, and then just 4 miles later it started flashing for empty. It was fairly typical tail end of rush hour traffic, i.e. some parts at 20mph, some parts at 50mph, and some parts in between. It wasn't stop and go traffic, and it wasn't cruising at 70mph traffic either.
    Should I be worried that the last bar only lasted 4 miles? Normally I can go about 450 miles between fillups during this time of year, but I've only gone about 425 miles since my last fillup right now.
    I know that the bar starts flashing empty when there's still some gas left. I've gone as much as about 25 miles with it flashing on empty, and I've read that I can probably even go farther than that (but I don't really have any reason to test that out). The most I've ever put in the tank is about 8.8 gallons, so I've never gotten anywhere close to the 9.5 gallons that it claims to hold. We'll see how much it requires tonight when I fill up at the gas station near my house (about 12 miles away from where I work).
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    So please remind me of the issue mentioned in the title. The most gas I've ever put in my 2009 Gen II is just over 9 gallons, 450+ miles (middle of August 2015) - I usually fill up at around 300 miles on the trip odometer, the gauge at just under ½ way, it is a VERY BAD IDEA to run out of gas, and there is absolutely no reason to let that happen since there are so many gas stations and at just over $2/gallon, no earthly reason to run out. It can be quite expensive to let the tank run dry. In many modern cars including the Prius, the fuel-pump is immersed in the tank to keep it cool, and can suffer overheating and damage if the tank runs dry! Run out at your peril! There's no excuse, unless your fuel gauge is not working! There's a reason why the last "pip" on the gauge flashes, it's warning you that you really …NEED TO GET GAS! …NOW!!!! - hope this helps - Wil
  3. cutter44
    cutter44 Member
    213
    MA
    I believe as soon as you hit one bar, that bar starts flashing, and it's also the same time your Cruising Range hits "0". You can go probably another 50 miles, but I've already started looking for a favorite gas station by then.
    WilDavis likes this.
  4. Mendel Leisk
    38,726
    The main "issue" is just a compulsion to run the tank near-dry. There is zero upside to this game.
    Peter Larsen and WilDavis like this.
  5. bisco
    49,490
    i think you are doing the right thing, asking here for advice. cause for concern? possibly. worry? absolutely not. 25 miles is not a big variance, nothing is exact in the prius fuel system. but only going 4 miles on the last bar is cause for concern.
    i think the best thing to do is run another tank and see how she does. if the same, or a similar thing happens, you may want to start be recalibrating the fuel gauge. all the best!(y)
  6. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    That's well under a 10% difference, which is nothing. You can get a greater variation on that just due to the weather (cold temperatures, rain, etc.). Don't worry about the difference. And don't tempt fate by making a habit of running the gas so low that that last bar flashes - there's almost no upside and a lot of potential downside. One trip to the dealer to reset the error codes that running out of gas might get you is far more hassle than even a couple of extra trips to the gas station every year is worth.
  7. Gabriel Rockman
    23
    2014 Prius c
    I filled it up all the way, but it only took 8.301 gallons last night. I don't know how much beyond 8.8 gallons my tank holds because that's the most I've ever put in it, but its supposed to hold 9.5 gallons.
    If it's flashing empty, and then I drive another 15 miles and it still only has room for 8.3 gallons, that does seem to be a bit too premature for it to flash empty.
    My commute to and from work is about 25 miles round trip, so I've never had any issue finishing my commute and filling up at a gas station near my house. I wouldn't end a trip with it flashing empty, but if it starts flashing empty during my trip, I know that I've got enough time to finish driving to work, and then drive home and fill up at the gas station right by my house. When it first starts flashing empty, that's not a "FILL UP NOW" sign. I know that there's still plenty of gas left in the tank, I just don't know how much.
    But driving 15 miles after it flashes empty, and then still only having room for 8.3 gallons tells me that either the gas tank is MUCH smaller than the 9.5 gallons advertised, or the fuel gauge isn't very accurate.
  8. Gabriel Rockman
    23
    2014 Prius c
    For yesterday's fillup, it started flashing after I'd driven 441 miles, and I filled up after 453 miles with 8.472 gallons. In the past I used to get to about 8.5 gallons before it started flashing empty. This time it seems to have gotten to about 8.3 before it started flashing, which is still better than the roughly 8.1 it did two times ago.
    I don't know how close in size my gas tank is to the advertised 9.5 gallons because the most I've put in is about 8.8 gallons, but when it starts flashing empty well ahead of the 9.5 gallons, that makes the last gallon of space not too useful (unless you're a daredevil, which I'm not, contrary to what people think with my habit of driving up to 20 miles after it starts flashing empty).
  9. Mendel Leisk
    38,726
    Following that logic, I've got pretty much half the tank that's just along for the ride: I fill up anytime the gas gauge is below half. Arguably, that's about every 3~4 weeks, so still not a frequent chore.
    I've found there can be things that bug the cr@p out of you, and then 20 years later, you wonder what all the fuss was about.
    Peter Larsen likes this.
  10. Sean Nelson
    421
    182
    That strikes me as saying that insurance is not too useful since you hardly ever use it. There are things in life that you have "just in case", and that extra gallon is one of them. You've gotta ask yourself where you draw the line? If hauling around an extra gallon is too much, how about hauling around extra quart quart? A cup? An ounce? The less "extra" you haul around, the greater the risk that you've cut things too close.
    Without any extra, then you'd almost certainly have already run out of gas once or twice, and the convenience of avoiding that kind of inconvenience makes it well worth it to haul around an extra gallon, IMHO.
  11. Gabriel Rockman
    23
    2014 Prius c
    It's about knowing that it's there just in case. If I knew that my car truly did have the 9.5 gallon capacity, it'd be different. But for all I know, my capacity is just 9 gallons, since I've never even run it that low. Part of the benefit of having insurance is the peace of mind that it gives. That if your house burns down, that you know that you're covered. If you have insurance, but you're not sure if it'll actually be there when you need it (kind of like us younger people are with social security), then a great deal of its benefit has been taken away.
    My complaint isn't that I have to haul the extra gallon around, it's that aside from trying to run my car out of gas or taking my car apart, I can't actually confirm that the extra gallon is there (I can only confirm about 0.3 gallons).
    And at the moment, it's also that the fuel gauge has started flashing sooner than it has in the past. I don't know if I can still safely go to 8.8 gallons, or if the capacity of the tank changed for some reason, and it's still got the same amount of fuel left as it did in the past, but the gas pumps are automatically stopping sooner than they did before.
  12. Gabriel Rockman
    23
    2014 Prius c
    Yesterday my car started flashing empty on the way to work. 10 miles later, on my way home, it stopped flashing empty, and went back to 1 bar. Then 5 miles after that it started flashing empty again. And then 3 miles later, I filled up with gasoline, but only needed 8.256 gallons to get to a full tank (for 448 miles).
    I think it's pretty clear that the fuel gauge is not working properly. This doesn't really affect my car's performance at all, and it is definitely a low priority issue. But it's still not working properly.
    Is there any simple things I could do to try to fix this issue?
  13. Mendel Leisk
    38,726
    A car with a needle gauge, you'ld never have this "issue". How to fix: fill up when you've got a couple of bars still showing.
  14. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I've seen my fuel gauge do the same thing; but I never get so low as to see it blink. It seems to be related to uphill downhill attitude of the car and position of the fuel level sensor.
  15. Sean Nelson
    421
    182
    If the gauge isn't located in the exact centre of the tank then its reading can vary when you drive between level ground and a grade (i.e., going up or down a hill) because the fuel will moves from one end of the tank to the other in accordance with the law of gravity.
    With analogue fuel gauges many of the cars I've driven tend to indicate there's a bit less fuel in the tank when going uphill. That kind of effect is harder to see in the Prius C because the fuel gauge has a much coarser indication, but if your fuel level is right near the boundary between, say, one and two bars then it sure wouldn't surprise me to see that happening.
    fuzzy1 and Mendel Leisk like this.
  16. Hey Gabriel you may want to like the two posts above since they get to the heart of the fluctuations. I've seen my fuel gauge on different occasions fluctuate both -1 and +1 tick just because the fuel level sensor says it's right in between. That would also explain why it may take a few extra miles to get the last bar to flash. So, nothing to worry about there. I think that your sensor is working as intended. On another note, I've noticed that the first tick goes from 9.50 to about 7.90 gallons; the scale is not linear.
  17. fuzzy1
    10,170
    Based on my experience with various cars over several decades, I think you are trying to extract more detailed and precise information from the gauge than it was intended to provide. Most fuel gauges are just cheap indicators, optimized for low manufacturing cost. They also contain significant 'customer expectation management' biases, e.g. margin at the bottom so customers cannot legitimately blame the car maker when they run out of fuel.
    The top of the gauge is not at the real top of the tank, the bottom of the gauge is not at at real bottom of the tank, the gauge subdivision markings are not at equally sized fuel increments, the gauge does not perfectly filter out the fluid 'slosh' from hills and corners and speed changes, and it doesn't read the same every time. Though my Prius fuel gauges haven't been nearly as bad as the analog gauges on some of my past cars.
    That 'extra', or 'insurance', was less than zero on the very first car I actually owned. It ran dry with the fuel needle still above E. It isn't real insurance if you merely take it on faith that the fuel might be there, when experience already includes events where it was absent.
    A later car had close to 30% of its claimed tank capacity below E, more than 4 gallons. Using the same safe lower limit gauge rule needed on the first car meant very premature refueling stops on one of my regular trip routes, in the severely overpriced fuel zone.
    In previous threads, I've better explained my methods and personal reasons for testing the lower levels of the fuel gauge on new-to-me cars. I don't expect understanding or agreement from drivers too young to remember the OPEC Oil Embargo, or who live in regions with no meaningful price competition (e.g. British Columbia), or who don't drive in areas with signs such as these:
