Fuel gauge issues.
Discussion in 'Prius c Main Forum' started by Usernameinuse, Oct 8, 2012.
  1. Usernameinuse
    Usernameinuse Junior Member
    30
    Driving on my original tank from dealer today from Upstate NY to NYC. On the way my C had 4 bars to begin then went to 3, then 2 after about 90 miles of traveling at avg of about 55mph. I watched the cruising distance go down to 1 but I still had 2 bars on my fuel gauge (and my crusing distance was conservative compared to my mpg reading the whole trip, which was hovering around 58mpg). The gauge went from 2 bars to one flashing bar in about 1 minute. I pulled into a gas station about 2 miles ahead and put in about 5 gallons... this put the fuel gauge up to 3/4s or about 3 bars above the halfway mark. What gives? I know there are fuel gauge issues but I thought with two bars I would have had plenty of time before I needed to fill up on these roads with these mpgs. Any insight?
  2. Tracy
    Tracy Member
    171
    101
    Others are having issues - some starting at 3 pips (like....suddenly running out of gas when it shows 3 pips!). So....a known situation. I normally watch my ECO screen but I'm watching my Trip info right now and the cruising distance to try and figure out my own system. I have 51 miles cruising distance when I went to 2 pips which doesn't correlate with simple division that each pip is about 1 gallon.
    From what you've described, I think I would be picking up the phone and having a chat with my dealer. I wonder if we'll see a recall on fuel gauges to correct this......???
  3. crebble
    crebble Member
    176
    47
    Shohola PA
    The fuel guage is non-linear. It will drop much faster after half a tank. You will stay at 2 bars until your displayed remaining range equals zero at which point you'll drop to 1 flashing red bar. You *should* still have about a gallon left at that point (how much of that is usable, I don't know) enough to get you at least 30-40 miles if you push it. Your partial fill-up sounds about right. 5 gallons plus 1 left in the tank. 6 /9.5 gallons= about 2/3rds full.
    Tracy likes this.
  4. Tracy
    Tracy Member
    171
    101
    Thank you VERY much - great info.
  5. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    the cruising range I found typically is till the low fuel indicator comes on, not empty, but I had noticed times where it went to 1 miles cruising range and it stayed there for 15 to 20 miles then beeped and came on, and other times it came on Im pretty sure before reaching 1.. I have comfortably driven 30 miles after the beep.
