Fuel Gauge needs to be reset, 2016 Prius V
Discussion in 'Prius v Main Forum' started by Anthony Calabretta, Sep 14, 2024 at 6:31 PM.
  1. Anthony Calabretta
    Anthony Calabretta Junior Member
    New Jersey
    I went to get a fill up of gas, but failed to turn the engine off like I usually do. The fill up did NOT register, it showed 2 "PIPS" before the fill up & that's where it stayed after the fill up, after driving 100 miles now the car low gas level display shows up. Of course there are still 300 miles worth of driving range left. Is there some way to reset the gauge/pips so it's accurate?
  2. whitrzac
    whitrzac Junior Member
    madison
    Are you sure you put gas in the car?
    I fill mine up all the time with it running and it registers fine.
    Could be a bad fuel pump/sender too
