Fuel gauge never moves even when out of gas.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brkpoint, Feb 26, 2014.
  1. brkpoint
    brkpoint Junior Member
    Indianpolis
    2008 Prius Touring.
    At 86,000 miles I got the red triangle of death and coasted off the interstate. Had the car towed to Toyota and they said there were no codes except it ran out of gas, even though the fuel gauge said it was 3/4 full. After running out of gas two more time I took it in and they unplugged the fuse and said it should be fine. (BTW there is no low fuel warning, just the red triangle and the eery sound of wind whistling as you glide). By this point I fill up when I have traveled 300 to 350 miles, which is my fuel gauge work-around. After running out of gas a couple more times I go back to Toyota, (we're past the 100K warranty now), they charge me $47 to rest the computer. I continue to run out of gas because the odometer has quit resetting when I refuel, so if I forget to manually rest the odometer or someone resets it by accident I mostly likely will run out of gas. Last trip in the Dealer told me I need a new gas tank for $733, I didn't do it because I felt like they are just guessing at what the issue is and don't really know. (these events involve the only two dealers in my city.)
    Recently wrote a letter to the North American CEO of Toyota describing my story, they can not prove there is an issue with the car or dealer because of no codes. They offer a voucher for $200, which I declined because they had several chances to fix the problem when it was under warranty and they just blew me off and I don't believe either dealership can actually fix it.
    Sorry this is long but if anyone has an idea on how to fix this or suggestions I would be extremely grateful for any counsel. (My last out of gas experience was in middle of nowhere and the temp was -14 - very scary). Other than the gas issue it's a great car.
    05 Prius NY likes this.
    51,155
    did you buy the car new?
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Have you heard about "Autobeyours"? They might be able to help you and save you some money. Not far from you unless you think a 85 mile road trip is too far.
    Here is a link to their website. They are well respected in the Prius Chat community and have been in business for a while now.
    Prius hybrids sales and service Scottsburg Indiana
    FWIW, I think you will find in the end the gas tank swap will fix the problem.
    Best of luck to you!
  4. Patrick Wong
    18,200
    6,493
    1. I suggest that you make it a habit to note your odometer reading and buy fuel after 250 miles since you probably are getting tired of running out of fuel and this really is not helpful to your traction battery's longevity, not to mention your peace of mind.
    2. When you are ready to fix the car, it is likely that a replacement fuel tank will help because the fuel gauge sender in the tank is probably stuck. As previously suggested, you may be able to purchase a used tank at autobeyours.com and they may be willing to install the tank for you.
  5. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Things break. That happens. Seeking out advice is good next step. But it does seem odd having waited so long... over 15,000 miles is a lot. How many gallons did it take to refill each time? Have you been estimating capacity using ODO & MPG values? Are you the only driver? Were you the only owner? Did they warn you about the damage that can be caused to both tank & battery from continuing to drive after having run out of gas?
  6. dorunron
    3,318
    1,105
    Houston, TX
    One other thing to consider is that you can't simply replace the sending unit that is inside the tank on the Prius. The North American Gen II Prius has a sealed tank with the parts inside virtually non serviceable. This includes the fuel pump, fuel filter and several other items enclosed in a sealed compartment.
    I know it sounds ridiculous, but it is what it is. That is why I said what I said about the swap of the tank fixing the problem. I understand the concern that is held since the dealer did not/would not/could not fix the problem. Sometimes the dealers are reluctant to use common sense. They tend to rely on specific codes and work flow procedures whereas an independent at times will use both the code/workflow process as well as common sense.
    Take a few minutes and read thru what galaxee posted here on Prius Chat a few years ago. This should give you a better understanding of the system and possibly clarify why it has been recommended to swap the tank.
    the gas bladder: exposed! | PriusChat
    Hope this helps you brkpoint!
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Total and complete BS.
    Not everything that goes wrong with a car "sets a code".
    For a "real" mechanic, it should be a fairly simple process to check the fuel gauge sender
    to see if it is not working......since that probably is the cause.
    I suggest that you contact the warranty help line for Toyota AND contact your local States Attorney's office to see what your state does to help with warranty problems.......and tell your dealer and Toyota that you are going to contact them.
    I hope you have kept all of the service receipts that show this has been an ongoing problem.
    If not, you are screwed warranty wise and contacting an independent shop might be your
    best alternative.
  8. Patrick Wong
    18,200
    6,493
    The fuel sender and fuel tank probably were covered under the 36 month comprehensive warranty, or best case, the Federal emissions warranty, and both had expired prior to 86K miles.
  9. Easy Rider
    982
    210
    N. Central Florida
    Some people just never ask the right questions.......including ME at times.
    If he really had some kind of bumper-to-bumper warranty that went to 100K, then the dealer is screwing him over.
    If he just had the standard warranty, he might be way beyond coverage for the gas tank and associated parts.
    And IF the $733 tank price included the labor to install it, he probably should have taken the $200 coupon and just been done with it.
    A used tank might be an option but that's a gamble too.
    Since when does any odometer automatically reset when you fill up with gas ??
    I've never seen one that does that.
    The MPG calculation resets but not the trip ODO.
    So......it seems pretty obvious that this person is NOT going to be able to revise his "routine" to deal with the
    absence of a gas gauge so he just needs to bite the bullet and get it fixed........or just learn to live with his own
    shortcoming of not being able to deal with manually tracking his gas usage.
  10. brkpoint
    Indianpolis
    Wow thank you for the advice. So I guess a new gas tank is the best solution. I average 140 miles every day so I fill up every two to three days.
    Thank you everyone.
    Note: it is the mpg calculator that stopped resetting and not the odometer - (incorrect terminology on my part)
    Also the warranty was supposed to be bumper to bumper for 100k. (Never used it )
  11. TBurnham
    TBurnham Junior Member
    Wichita,KS
    I had a similair problem on my 2006 at about 75K miles. My dealer did the re-calibration of the fuel gauge and told me to run SeaFoam through two tanks of fuel and I have not had a problem since (now 155K). There are instructions on the forum on how to run the calibration yourself without Techstream. I always assumed the Sea Foam additive was to help dislodge any residue in the tank. :: Could running the fuel gauge calibration help ? or prove that the sending unit is bad ? ( I personally like to be convinced of something before parting ways with $500 +).
  12. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
  13. Easy Rider
    982
    210
    N. Central Florida
    The MPG calc. stopped resetting because the fuel sensor never reports that you put any gas in.
    And I may be wrong but I don't think anybody EVER offered a 100K BtB warranty......as standard equipment, that is. The 100K warranties are typically for the "drive train" only.
