Fuel Inclination meter reset
Discussion in 'Gen 2 Prius Fuel Economy' started by xsmatt81, Nov 12, 2008.
  1. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    A. Start car in Ready Mode
    B. Go to "Trip A"
    C. Power down
    D. Make sure your foot is off of the
    brake pedal.
    E. Push in and hold the
    “ODO/TRIP” button.
    F. Turn the power switch ON
    (push the “POWER” button twice).
    G. Turn the “ODO/TRIP” button OFF,
    then ON 3 times within 5 seconds.
    H. Continue to hold the “ODO/TRIP”
    button until the “ODO” indicator in
    the display turns off and a 6–digit
    code (######) is displayed.
    I. Release the“ODO/TRIP” button.
    J. Push and hold the “ODO/TRIP”
    button for 5 seconds or more
    again. The 6–digit code (######)
    will then change to a 5–digit
    code (#####).
    K. After “1” is displayed at the 3rd
    digit of the 5–digit code, release
    the “ODO/TRIP” button.
    L. Approximately 5 seconds after “1”
    is displayed at the 3rd digit, the
    “TRIP A” indicators are displayed,
    and the odometer returns to the
    normal operation.[/i]
    NOTE:
    �� The “TRIP A” mileage will revert to
    0.0 miles in this procedure.
    �� Do not drive the vehicle before the
    reset procedure has been completed.
    HINT:
    If a write error occurs, start the
    procedure again from the beginning.
    the 5 digits you see will be
    X = first two digits
    Y = middle digit
    Z = last
    X: Values Written Into Meter
    (Longitudinal Direction)
    Y: Write Status and Result
    Z: Values Written Into Meter
    (Lateral Direction)
    Write Status and Result:
    0: Writing
    1: Write Completetd
    2: Write Error
    3: Write Canceled
    I think I will try this, my fuel tank is all screwy lately. Temps are normal here..no more then 55 at night..70's during day.
    put a little over 9 gallons on last fill up. First pip disappeared at just 65miles with moderate driving with all trips being over 7 miles or so. It's been acting up the last few fill ups. This is new behaviour for the car, for the life of the car it almost always drops the first pip @90-110 miles.
    Figure would give this a try if I can find a "level" surface to perform the reset.
    mainly I posted this to see what other's experience was with this reset procedure.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Good luck, let me know if you get it to work. I tried for almost an hour a couple years ago and never got the procedure to work....I kept getting hung up b/w step G & H and it would just switch to Trip B and never clear the odometer or go to the reset part.
  3. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    I did this in a 2001 Prius and could not detect any difference in fueling afterwards. Therefore in my case the tank bladder was probably responsible for the lower refueling capacity.
  4. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    :dizzy: Wow...that looks super complex. I may give it a whirl in my garage, it's pretty level there. What's the benefit to this procedure?
  5. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    +1 yeah, what does this do?
  6. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    all this does is reset the inclination sensor, which is only part of various sensors that are used to sense the level of gasoline in your tank, i think
    you left out step a (1)
    Connect the connector and install the meter securely in the position shown in the illustration so that it is inclined at a 20 degree angle to the vehicle's vertical line A.
    if the inclination sensor is not at a 20 degree angle you are probably doing it wrong or throwing it off
  7. rigormortis
    1,340
    26
    san jose, ca
    i cannot find any information about specifically adjusting, resetting, calibrating, etc the fuel meter in the combination display.
    The fuel level is calculated by the meter ECU in
    accordance with the signals of the sender gauge
    located in the sub tank and the vehicle speed signal
    received from the brake ECU. At this time, corrections
    are made by the signals from the inclination sensor
    that detect the vehicle's longitudinal and latitudinal
    inclinations and the fuel temperature sensors that
    detects the temperature in the fuel tank.
  8. xsmatt81
    522
    Vegas
    I had a go at it last night and was unsuccessful.
    I was in a hurry though. Will try again sometime since I am stubborn like that
    I am not so certain it will do anything, may just take it into dealer sometime.
  9. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I reset mine a couple of months ago. Nothing much changed because, I assume, there was nothing wrong with the calibration in the first place. The ScanGauge has since confirmed that what the gas gauge tells me is approximately in line with the raw reading from the float.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Bear68 posted instructions some time back that were way simpler than this. I'm not sure that it reset the exact sensor this does, but it was a reset for the actual "how many pips = how full the tank is" sort of thing. I remember that he said that the tank needed to be over half full, however.
  11. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    if it ain't broke, don't try and fix it for the sake of tinkering. the inclination sensors correct for the car being on an incline when calculating what to display on the fuel gauge. you could throw off their calibration if you're not on a level surface when you do it. they recommend doing this on an alignment rack...
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    At one point over the summer I parked on a fairly steep slope
    to the right, leaving the system powered on, to take a quick stop
    into a store. A little while later I noticed that the MFD
    average had reset itself. Apparently the strong tilt had been
    interpreted as a refueling event.
    I also went over some washboard sand roads over the summer that
    were bouncing the whole instrument binnacle up and down so hard
    I can't imagine how the sensors would be able to hold on to any
    concept of reality under that kind of punishment.
    I've never reset my sensors since the gauge and the sender seem
    pretty well matched, but I might play one of these days.
    _H*
  13. brick
    brick Active Member
    1,083
    79
    Upstate NY
    In my case I thought that the gauge might have been off its calibration since my standard "fill" is maybe 7 gallons, less if it's cold. It would have been nice to find that there was an extra usable gallon or two sloshing around in there, but unfortunately that isn't the case. Instead I just run it down a bit farther since I have the ScanGauge giving me enough resolution to be comfortable.
  14. xsmatt81
    522
    Vegas
    meh.
    this must be for older models like 2004.
    don't work. Unless Iam just not getting it.
    I think I will leave it alone
  15. efusco
    19,891
    1,194
    Nixa, MO
    Didn't work on my '04 either.
