Fuel mileage and battery age
Discussion in 'Gen 3 Prius Main Forum' started by Noz, Feb 24, 2010.
  1. Noz
    Noz New Member
    28
    Los Angeles
    Any correlation between battery life and mileage over time?
  2. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    The DOE ran the Gen 1 Prius out to 160,000 miles, and while they found the battery capacity degraded by ~50% there was no significant drop in mileage. The batteries in the Gen 2 & 3 are improved over the Gen 1, and should be even better. Under most normal circumstance, mileage is not a major function of battery capacity.
    http://avt.inel.gov/pdf/hev/end_of_life_test_1.pdf
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Be aware that the 12v battery (like any car) has a life of about 4 years (like any car) and that some of it's failure modes can effect mileage, as the car is trying to recharge it constantly. So if you 12v battery is over 4 years old, have it checked out.
    (unlike any car, the prius does not start slower as the battery ages, as the 'starter' runs off the 201 v battery)
